  4. DC DC 6W
  5. URB2405/URB2412/URB2424YMD-6WR3 DC-DC isolated voltage stabilization power module 24V to 5V/12V/24V single output power converter
    $3.25
URB_YMD-6W Series Mode list 拷贝
DC DC:
https://drive.google.com/drive/folders/1kljPbgQN3S1XFjF3nZ8WgXzOJ_IAHzl1?usp=sharing
TD521D485H-A
https://drive.google.com/drive/folders/1kTt0Z3hjKKrIF3OCIDGdwQ4KotDJ8SGA?usp=sharing
AC DC:
  • Wide input voltage range(4:1),Output 6W
  • Conversion efficiency91%(Typ)
  • Isolation voltage 1500Vdc
  • Ultra-low standby power consumption:0.036W
  • (S tyu pp ie craf lavsat lsutear)tup:1mS(typical value)
  • Working temperature range:-40°C~+85°C
  • Input undervoltage, output short circuit, overcurrent, overvoltage protection
  • Metal case, low output ripple
  • International standard pins, PCB board in-line
UR(A)A_YMD-6WR3 series product output power is 6W, 4:1 wide voltage input range, efficiency up to 91%, conventional isolation voltage of 1500VDC, allowable operating temperature -40℃ to +85℃, with Input under-voltage protection, output over-voltage, over-current, short-circuit protection functions, bare metal meets CISPR32/EN55032 CLASS A, widely used in medical, industrial control, electric power, instrumentation, communication, railway and other fields.
Input current (full loaded/no loaded)24VDC nominal input series, nominal , nominal input voltage
3.3V--235/1241/2mA
Others--294/1301/2
48VDC nominal input series, nominal , nominal input voltage3.3V--118/0.5121/1
Others--147/0.5151/1
110VDC nominal input series, nominal ,nominal input voltage3.3V--51/0.353/0.5
Others--64/0.366/.5
Reflected ripple current24VDC nominal input series, nominal ,nominal input voltage--40--mA
48VDC nominal input series, nominal ,nominal input voltage--30--
110VDC nominal input series, nominal ,nominal input voltage--20--
Impulse voltage
(lsec.max)
24VDC nominal input series, nominal ,nominal input voltage-0.7--50VDC
48VDC nominal input series, nominal ,nominal input voltage-0.7--100
110VDC nominal input series, nominal ,nominal input voltage-0.7--200
Starting voltage24VDC nominal input series, nominal ,nominal input voltage----9
48VDC nominal input series, nominal ,nominal input voltage----18
110VDC nominal input series, nominal ,nominal input voltage----40
Input undervoltage protection24VDC nominal input series, nominal ,nominal input voltage5.56.5--
48VDC nominal input series, nominal ,nominal input voltage1215.5--
110VDC nominal input series, nominal ,nominal input voltage3236--
Start timeNominal input voltage and constant resistance load--1--ms
PI
Hot plug
Project nameWorking and testing condition+Vol-Vo2
Output loadload percentage0%--100%0%--100%
--±1.0%±2.0%--±2.0%±3.0%
Linear adjustment rateInput voltage range --±0.2%±0.5%--±1.5%±2.0%
Load adjustment rate20%~100% load,balanced load--±0.5%±1.0%--±4.0%±5.0%
Startup delay time
--1ms----1ms--
Output voltage regulationInput voltage range--No adjustmant end----No adjustmant end--
Dynamic Response step deviation25% nominal load step--±3.0%±5.0%--±3.0%±5.0%
Dynamic Response recolvery time--300μs500μs--300μs500μs
Output overvoltage protectionFull voltage range input
110% Vo--160% Vo
Output overcurrent protectionFull voltage range input110% Io150% Io200% Io
Output short circuit protectionFull voltage range inputsustainable, self-healing
Notes: ①For product models with output voltages of ±5VDC and ±9VDC, under 0% - 5% load conditions, the maximum output voltage accuracy is ±5%; ②When tested under 0%-00% load working conditions, the index of load regulation rate is ±5%; ③0%-5% load ripple & noise less than or equal to 5%Vo. Ripple and noise test method Twisted pair test method, which can add capacitive load at the output to reduce light load ripple.
General Characteristics
ItemsWorking conditionsMin.Typ.Max.Units
Insulation voltageinput-output, test time is 1 minute, lwakage current is less than 1mA1500----VDC
Insulation resistanceinput-output, insulation voltage 500VDC1000----
Isolation capacitorinput-output,100KHz/0.1V--1000--pF
Working temperatureUsing the reference temperature derating curve-40---85
Storage temperature
-40--+125
Operating maximum case temperature
----+100
Storage humidityno condensation5--95%RH
Pin soldering temperaturesolder joint distance from shell 1.5mm, 10seconds----+300
On-off levelPWM model--250--KHz
Shock
10-55Hz, 10G,30min, alongX,Y and Z
Shell matereial
Aluminum shell
Minimum time between failuresMIL-HDBK-217F@25℃--2X105--Hrs
More detail please contact us: sales@hlktech.com
