HLK-LD2402 24G millimeter wave radar induction module LD2402 human presence static micro motion sensor module
Visitor5087
Price$0.99
1. Introduction
HLK-LD2402 is a static human life presence sensor from Hailingke, which includes extremely simplified 24GHz sensor hardware and intelligent algorithm firmware for human micro motion sensing.
The hardware is equipped with AIoT millimeter wave sensors, high-performance 24GHz one transmitter one receiver antennas, and peripheral circuits; The human presence sensing algorithm adopts millimeter wave radar distance measurement technology and advanced proprietary radar signal processing technology of radar chips to achieve precise perception of motion, micro motion, and human presence. The firmware of the human presence sensing intelligent algorithm is mainly used in indoor scenes to sense whether there is motion, micro movement, or the presence of a human body in the area, and to refresh the detection results in real time.
The maximum sensing distance of HLK-LD2402 for a moving human body is 10m, and the sensing distance range, triggering and holding thresholds for different intervals, and unmanned reporting time can be easily configured. HLK-LD2402 supports GPIO and UART interfaces, plug and play, and can be flexibly applied to different intelligent scenarios and terminal products. Simultaneously supporting automatic generation of detection thresholds, reducing manual debugging, improving detection accuracy, simplifying installation processes, and facilitating large-scale deployment.
2. Product features and advantages
Equipped with single-chip intelligent millimeter wave sensor SoC and intelligent algorithm firmware
Ultra small sensor size: 20mmX20mm
Load default human body sensing configuration, plug and play
24GHz ISM frequency band, can be certified by FCC, CE, and non commission spectrum regulations
3.3V and 5V power supply, supporting a wide voltage range of 3.0V~3.6V and 4.5~5.5V
The average working current is 50mA
Detecting targets for motion, micro motion, and the presence of a human body
Real time reporting of detection results
Provide visualization tools that support configuring detection distance intervals and target disappearance delay times
Support automatic generation of detection thresholds
Support the division of sensing range and completely shield any interference outside the interval
The maximum distance of motion human body sensing is 10m
Large detection angle, with a coverage range of ± 60 °
Support multiple installation methods such as hanging on the top and wall
Trigger and maintain state independent configuration, strong anti-interference ability
3. Application
Smart Home
Sensing the presence and distance of the human body, reporting detection results for the main control module to intelligently control the operation of household appliances.
Smart security and protection
Inductive access control, building intercom, electronic peephole, etc.
Intelligent Business
Identify human proximity or distance within the set distance range; Timely light up the screen and keep the device on while the human body is present
Smart lighting
Identifying and perceiving the human body, precise position detection, can be used for lighting equipment in public places (induction lights, bulb lights, etc.).
4. Specification parameters
HLK-LD2402 is a static human life presence sensor developed based on the Hailingke millimeter wave sensor chip. The sensor adopts FMCW frequency modulation continuous wave, combined with radar signal processing and built-in intelligent human sensing algorithm, to detect human targets in the set space and update the detection results in real time. By using HLK-LD2402, users can quickly develop their own precise human presence sensing products.
The hardware mainly consists of a fully integrated intelligent millimeter wave sensor SoC, a 24GHz transmitter receiver antenna, and a main control MCU;
The software is equipped with intelligent human presence sensing firmware and visual configuration tools to achieve flexible configuration of sensing distance, trigger and hold thresholds, and unmanned reporting time for human body sensing functions.
The specifications of HLK-LD2402 are shown in Table 2-1.
Parameters | Min | Typ | Max | Unit | Remark |
Hardware specifications | |||||
Support frequency | 24 | - | 24.25 | GHz | Compliant with FCC CE、 No committee certification standards |
Support maximum sweep bandwidth | - | GHz | - | GHz | |
Maximum equivalent omnidirectional radiation power | - | 11 | - | dBm | - |
Supply Voltage | 3.0 | 3.3 | 3.6 | V | - |
Add LDO power supply voltage | 4.5 | 5 | 5.5 | V | Default not pasted |
Size | - | 20X20 | - | mm | - |
Environment temperature | -40 | - | 85 | °C | - |
HLK-LD2402 System Performance | |||||
Detection range (wall mounted) | - | 10 | - | m | motion human body goals |
- | 6 | - | m | micro-motion human body goals | |
- | 5 | - | m | static human body goals | |
Detection range (ceiling mounted) | - | 5 | - | m | motion human body goals |
- | 4 | - | m | micro-motion human body goals | |
- | 4 | - | m | static human body goals | |
- | 3 | - | m | Lying human body target | |
Detection accuracy | - | ±0.15 | - | m | |
Average working current | - | 50 | - | m | |
Data refresh cycle | - | 165 | - | m |
