HLK-20M24 AC-DC 24v 20w Step Down mini Power Supply Module Converter Intelligent household switch power module
Visitor6387
Price$2.50
Wide range input 85-265VAC/70-350VDC
Working Temerature -25—+60 ℃
Storage temperature -40—+80 ℃
Relative humidity 5—95 %
Altitude ≤2000 m
Input vlotage range 85-265VAC/70-350VDC
The maximum input current ≤0.4A
Input inrush current ≤34A
Input low start ≤50mS
External fuse recommended 2A/250Vac or 10Ω wire wound resistance, Slow blow
Full-load rated output voltage 24.0±0.2%
Load regulation ±0.5%
Ripple/Noise ≤70mVp-p(Typ:50)
Meet UL/CE requirements
