  4. DC DC 1W
  5. B1205D-1WR3 DC-DC isolated non stabilized output power module B1203/09/12/15/24D-1WR3 single output power converter
    $1.13
B_D-1WR3 Series Mode list 拷贝 (1)
  • Fixed voltage input, isolated non stabilized output, power 1W
  • Isolation voltage 1500VDC/1min, 3000VDC/1s
  • Low no-load power consumption: 0.025W (TyP.)
  • Working environment temperature: -40 ℃ C~+85 ℃ C
  • Efficiency up to 91%
  • Output short circuit protection: sustainable short circuit protection, automatically restoring international standard pin mode
  • Small SIP packaging
  • Low ripple/noise (20MH bandwidth): 30mVp-p (tyP.)
  • Over temperature protection and output sustainable short circuit protection ROHSMTBF ≥ 3.5 million hours (3500000 Hrs)
Input current (full load/no load)3.3VDC Input Series--378/8-/15m'A
5VDC Input Series--227/5--/10
12VDC Input Series--93/2--/5
15VDC Input Series--74/2--/4
24VDC Input Series--46/1--/2
Reflection ripple current
--15--m'A
Impulse voltage
(lsec.max)
3.3VDC Input Series-0.7--5VDC
5VDC Input Series-0.7--9
12VDC Input Series-0.7--16
15VDC Input Series-0.7--20
24VDC Input Series-0.7--30
Output Voltage AccuracySee Error Envelope Curve----±15.0%
Linear adjustment rateInput voltage variation ±1%3.3V Input----±1.5%
others----±1.2%
Load adjustment rate10%~100% load3.3VDC Output--1520%
5VDC Output--1015%
9VDC Output--810%
12VDC Output--710%
15VDC Output--610%
24VDC Output--510%
----±0.03%/℃
Output short circuit protectionContinuous short circuit protection, automatic recovery--
1.  Standard Application:
 If further reduction of input and output ripple is required, a capacitor filtering network can be connected at the input and output terminals, and the application circuit is shown in Figure 1. However, attention should be paid to selecting appropriate filtering capacitors. If the capacitance is too large, it is likely to cause startup problems. For each output, while ensuring safe and reliable operation, the recommended capacitive load values are detailed in Table 1
Vin (vdc)Cin(uF)Vo(Vdc)Cout(uF)
3.3/54.73.3/510
122.294.7
152.2122.2
241151
241
                                                               Table 1 Recommended capacitive load values for details
2. EMC typical application:
Vin (Vdc)3.3/5/12/15/24
 C1/C24.7uF/50V
C3See the cout of Table 1
LDM4.7uH
CY270pF/2KVDC
                         Table EMC parameter recommendation
3. Notes:Output Load Requirements
