  4. AC DC 20W
  5. HLK-20M12 AC/DC 12v 20w Step Down mini Power Supply Module Converter Intelligent household switch power module
    $2.45
product list
Wide range input 85-265VAC/70-350VDC
Working Temerature                  -25—+60 ℃
Storage temperature                 -40—+80 ℃
Relative humidity                       5—95 %
Thermal methods                       Natural cooling
Atmospheric pressure                80—106 Kpa
Altitude                                      ≤2000 m
Vibration coefficient                  10~500Hz,2G10min./1cycle, 60min.each along X,Y,Z axes
Rated input voltage                          100-240Vac
Input vlotage range                          85-265VAC/70-350VDC
The maximum input current             ≤0.4A
Input inrush current                         ≤34A
Input low start                                 ≤50mS
External fuse recommended           2A/250Vac or 10Ω wire wound resistance, Slow blow
Full-load rated output voltage                       12.0±0.2%
Load regulation                                                     ±0.5%
Switching on/off overshoot amplitude                (Rated input voltage, output plus10% load)≤5%Vo
Output over-current protection Output maximum load             110-130% A
Ripple/Noise                                                ≤70mVp-p(Typ:50)
Meet UL/CE requirements
