  4. DC DC 1W
  5. Hot Sale B0505S-1W3 5V to 5V DC-DC Step Down Power Converter Module Transfer Efficiency 88%(Typ)passed UL/CE/FCC certifications
    $0.45
B05XX Series Mode list
Download Files
2. transfer efficiency 88%(Typ)
10. Adopts high quality environmental protection, waterproof and heat conducting adhesive for filling and sealing, moisture-proof and vibration proof, meeting the waterproof and dustproof IP65 standard
Storage temperture-40—+80 ℃
Related input voltage5Vdc
Input voltage range4.5-5.5Vdc
Maximum input current≤0.3A
Reflection ripple current15mA
DC5V rated input voltage series
Impulse voltage≤9Vdc
Starting voltage4.5Vdc
Start-up delay---msRated input voltage and costant resistance load
Output Characteristics(12v/84mA)
No load rated output voltage12V±15%Vdc
Short-time maximum output current≥84mA
Rated output current84mA
Voltage regulation±1.5%
Load regulation ±6%
Transfer efficiency Vin=12Vdc, output full load 88%
Output grain sweep noise(mVp-p)Pure resistance load, 20MHz bandwidth, peak to peak valuemV
Outputting the maximum voltage 110-160%Vdc
Isolation capacitanceInput- output, 100KHz/0.1V 20pF-
Cout CapacitanceFilter capacitor2.2-10μA/50V
