Welcome to Contact Us for Free Sample B0505S-1W2 5V to 5V 1W DC-DC Power Module
Visitor5308
Price$0.45
2. transfer efficiency 80%(Typ)
10. Adopts high quality environmental protection, waterproof and heat conducting adhesive for filling and sealing, moisture-proof and vibration proof, meeting the waterproof and dustproof IP65 standard
Related input voltage | 5 | Vdc | |
Input voltage range | 4.5-5.5 | Vdc | |
Reflection ripple current | 15 | mA | DC5V rated input voltage series |
Impulse voltage | ≤9 | Vdc | |
Starting voltage | 4.5 | Vdc | |
Start-up delay | --- | ms | Rated input voltage and costant resistance load |
Input filter type | Capacitance filter type | ||
Output Characteristics(15v/67mA)
No load rated output voltage | 15V±15% | Vdc | |
Short-time maximum output current | ≥77 | mA | |
Rated output current | 67 | mA | |
Voltage regulation | ±1.5 | % | |
Load regulation | ±6 | % | |
Transfer efficiency | Vin=15Vdc, output full load 80 | % | |
Output grain sweep noise(mVp-p) | Pure resistance load, 20MHz bandwidth, peak to peak value | mV | |
Output over-voltage protection | Outputting the maximum voltage 110-160% | Vdc | |
Isolation capacitance | Input- output, 100KHz/0.1V 20pF | - |
