  4. DC DC 5W
  5. URA1D05YMD-5WR3 dc dc step down power converter module URA1D03/09/12/15/24YMD-5W stabilized dual output
    $3.66
URA-YMD-5W Series Mode list
  • Wide voltage range input (4:1 ),output:5W
  • Conversion efficiency :90% (Typ) )
  • Isolation voltage :1500Vdc
  • Standby power consumption :0.036W (Typ) )
  • Quick start :1mS (Typ) )
  • Operating temperature range :-40~+85°C
  • Input undervoltage, output short circuit, overcurrent, overvoltage protection
  • Metal shell, low output ripple
  • International standard pins, PCB board in-line installation
The output power of UR(A)B_YMD-5WR3 series products is 5W, 4:1 wide voltage input range, efficiency up to 90%, 1500VDC conventional isolation voltage, allowable operating temperature -40℃to+85℃, with output overvoltage, overvoltage Flow and short circuit protection functions, the bare metal meets CISPR32/EN55032 CLASSA, and is widely used in medical, industrial control, electric power, instrumentation, communication, railway and other fields.
EInput Features
Project Working conditions Min. Typ.Max. Unit
Input current
(full load/no load)
24VDC nominal input series, nominal input voltage
3.3V201/1206/2mA
Other245/1251/2
48VDC nominal input series, nominal input voltage
3.3V100/0.5103/1
Other123/0.5126/1
110VDC nominal input series, nominal input voltage
3.3V44/0.345/0.5
Other50/0.3 55/0.5
Reflected ripple current24VDC nominal input series, nominal input voltage-40-mA
48VDC nominal input series, nominal input voltage-30-
110VDC nominal input series, nominal input voltage-20-
Impulse voltage
(Isec.max)
24VDC nominal input series, nominal input voltage-0.7-50VDC
48VDC nominal input series, nominal input voltage-0.7-100
110VDC nominal input series, nominal input voltage-0.7-200
Starting voltage24VDC nominal input series, nominal input voltage--9
Input undervoltage
protection
24VDC nominal input series, nominal input voltage5.56.5
48VDC nominal input series, nominal input voltage1215.5
110VDC nominal input series, nominal input voltage3236
Startup time Nominal input voltage and constant resistance load
1mS
PI type
Hot plug
Not support
Remote control(Ctrl)* Module on
Ctrl floating or connected to TTL high level
(3.5-12VDC)
Input current at shutdown -01mA
Note: *Ctrl control pin voltage is relative to input pin GND
