  3. Sensor Module
  5. Hi-link semiconductor fingerprint recognition sensor module HLK-ZW0906 capacitive touch fingerprint door lock acquisition test kit/development board
    $5.32
fingerprint module select list (2)
ZW0919: https://drive.google.com/drive/folders/11Hfr6bKT7IVFzgiRuf_XJhGJf0UnAFrK
ZW0906: https://drive.google.com/drive/folders/1Bf8uB-RA9bikIY9IvqDmcZD6dwdlEOwr
ZW0905: https://drive.google.com/drive/folders/1ZWkALY4HV5pF1nqXNWVdMYNIRgHB01zq
ZW0901: https://drive.google.com/drive/folders/1XtCFsMZ8JKsQx3yhjuWqhK7gvXFB9qMy
ZW0642: https://drive.google.com/drive/folders/1jXBPrjv7TLsIKRhWg4bhauMUmAHeT7RJ
ZW0623: https://drive.google.com/drive/folders/1ErDwzF-Hok0L3yVdE5GFwmbTEP8gphVJ
ZW0608: https://drive.google.com/drive/folders/1fUZlFCNMDEeryqCrYP1cqlvFcZ00cOCG
ZW111: https://drive.google.com/drive/folders/152YhI17TDGtX6wI1UvALbLdHL6ZlcsFw
ZW101: https://drive.google.com/drive/folders/1vSlF8b2zq1eI6UpXk3Jh3JKzu5nJ_RYs
ZW0906-2
Fingerprint identification module is used for user's identity determination, when the user touches the fingerprint identification module with his/her finger, the fingerprint identification module will scan the user's fingerprints, and the algorithm chip can obtain the fingerprint image data for registration and comparison operation. This product is suitable for various applications that require fingerprint identification.
Parameters
Technical indicators
ItemParameter
Storage
100 fingerprint data as standard
FRR.                                                         <3%
FAR.                                                    <0.001%
Fingerprint sensor shape
round
Image gray level                                              8-bit grayscale
Service life                                              one million times
Static electricity test                      Contact discharge ±8KV/Air discharge ±15KV
Data interface                                             UART (TTL level)
Sensor surface hardness                                                     3H
Working temperature and humidity range                                 -25℃~+70℃; 45%~85%RH
Storage temperature and humidity range                                 -40℃~+85℃; 45%~95%RH
Mechanical characteristics
Project Description Unit
Dimensions Φ12.8mm mm
Ribbon5.6*4.8mm
Resolution ratio112*96
Electrical parameters
ItemMin Typical Max Unit
Supply voltage3.03.3 3.6V
Standby current (sensor) -1012 μA
Operating current (algorithm MCU) 2435 50mA
Maping  time506070mA
Eigenvalue generation time657080ms
Comparison time206001100ms
Power-on start time -67100ms
ESD rating
Non-contact discharg
-15-KV
Contact discharge-8-KV
Application-06
