  3. Sensor Module
  5. Hi-link semiconductor fingerprint recognition module HLK-ZW0906 capacitive touch fingerprint door lock acquisition sensor module
    $2.95
fingerprint module select list (2)
ZW0906-2
Fingerprint identification module is used for user's identity determination, when the user touches the fingerprint identification module with his/her finger, the fingerprint identification module will scan the user's fingerprints, and the algorithm chip can obtain the fingerprint image data for registration and comparison operation. This product is suitable for various applications that require fingerprint identification.
Parameters
Technical indicators
ItemParameter
Storage
100 fingerprint data as standard
FRR.                                                         <3%
FAR.                                                    <0.001%
Fingerprint sensor shape
round
Image gray level                                              8-bit grayscale
Service life                                              one million times
Static electricity test                      Contact discharge ±8KV/Air discharge ±15KV
Data interface                                             UART (TTL level)
Sensor surface hardness                                                     3H
Working temperature and humidity range                                 -25℃~+70℃; 45%~85%RH
Storage temperature and humidity range                                 -40℃~+85℃; 45%~95%RH
Mechanical characteristics
Project Description Unit
Dimensions Φ12.8mm mm
Ribbon5.6*4.8mm
Resolution ratio112*96mm
Electrical parameters
ItemMin Typical Max Unit
Supply voltage3.03.3 3.6V
Standby current (sensor) -1012 μA
Operating current (algorithm MCU) 2435 50mA
Maping  time506070mA
Eigenvalue generation time657080ms
Comparison time206001100ms
Power-on start time -67100ms
ESD rating
Non-contact discharg
-15-KV
Contact discharge-8-KV
Application-06
