  3. Sensor Module
  5. Hi-link surface array semiconductor fingerprint recognition module HLK-ZW0901 capacitive touch fingerprint sensor module
    $2.86
fingerprint module select list (2)
ZW0901-2
Consumers use fingerprint recognition modules to determine user identity. When the user touches the fingerprint recognition module with his finger, the fingerprint recognition module will
scan the user's fingerprint, and the algorithm chip can obtain the fingerprint image data for registration and comparison.
Parameters
Technical indicators
ItemParameter
Storage
50 fingerprint data as standard
FRR.                                                         <3%
FAR.                                                    <0.001%
Fingerprint sensor shape
round
Image gray level                                              8-bit grayscale
Service life                                              one million times
Static electricity test                      Contact discharge ±8KV/Air discharge ±15KV
Data interface                                             UART (TTL level)
Sensor surface hardness                                                     3H
Working temperature and humidity range                                 -30℃~+70℃; 45%~85%RH
Storage temperature and humidity range                                 -40℃~+85℃; 45%~95%RH
Mechanical characteristics
Project Description Unit
Dimensions Φ12.8mm mm
Ribbon5.6*4.8mm
Resolution ratio112*96mm
Electrical parameters
ItemMin Typical Max Unit
Supply voltage3.03.3 3.6V
Standby current (sensor) -912 μA
Operating current (algorithm MCU) -25 50mA
Picture collection time
150155160
ms
Eigenvalue generation time200220250ms
Comparison time10180400ms
Power-on start time -100-ms
ESD rating
Non-contact discharg
--15KV
Contact discharge--8KV
Application-06
