  3. Sensor Module
  5. Hi-link fingerprint recognition module HLK-ZW0642 capacitive touch ball racket shaped fingerprint door lock acquisition sensor module test kit/ development board
    $7.18
fingerprint module select list (2)
ZW0642-2
The fingerprint recognition module is used to determine the user's identity. When the user touches the fingerprint recognition module with his finger, the fingerprint recognition module will scan the user's fingerprint. The algorithm chip can obtain the fingerprint image data for registration and comparison operations. This product is suitable for various occasions requiring fingerprint recognition.
Parameters
Technical indicators
ItemParameter
Storage
100 fingerprint data as standard
FRR.                                                         <3%
FAR.                                                    <0.001%
Fingerprint sensor shape
round
Image gray level                                              8-bit grayscale
Service life                                               million times
Voltage and current
                                            3.3V/50mA
Static electricity test                      Contact discharge ±8KV/Air discharge ±15KV
Data interface                                             UART (TTL level)
Sensor surface hardness                                                     3H
Working temperature and humidity range                                 -20℃~+70℃; 45%~85%RH
Storage temperature and humidity range                                 -40℃~+85℃; 45%~95%RH
Mechanical characteristics
Project Description Unit
Dimensions Φ14mm mm
Ribbon8.0*8.0mm
Resolution ratio 160*160mm
ZW0642-6
ZW0642-04
Electrical parameters
ItemMin Typical Max Unit
Supply voltage3.03.3 3.6V
Standby current (sensor) -912 μA
Operating current (algorithm MCU) -25 50mA
Picture collection time
150155160
ms
Eigenvalue generation time200220250ms
Comparison time10180400ms
Power-on start time -100-ms
ESD rating
Non-contact discharg
--15KV
Contact discharge--8KV
Application-06
