Hi-link fingerprint recognition module HLK-ZW0919 capacitive touch ball racket shaped fingerprint door lock acquisition sensor module test kit/ development board
Visitor2932
Price$5.38
ZW0919: https://drive.google.com/drive/folders/11Hfr6bKT7IVFzgiRuf_XJhGJf0UnAFrK
ZW0906: https://drive.google.com/drive/folders/1Bf8uB-RA9bikIY9IvqDmcZD6dwdlEOwr
ZW0905: https://drive.google.com/drive/folders/1ZWkALY4HV5pF1nqXNWVdMYNIRgHB01zq
ZW0901: https://drive.google.com/drive/folders/1XtCFsMZ8JKsQx3yhjuWqhK7gvXFB9qMy
ZW0642: https://drive.google.com/drive/folders/1jXBPrjv7TLsIKRhWg4bhauMUmAHeT7RJ
ZW0623: https://drive.google.com/drive/folders/1ErDwzF-Hok0L3yVdE5GFwmbTEP8gphVJ
ZW0608: https://drive.google.com/drive/folders/1fUZlFCNMDEeryqCrYP1cqlvFcZ00cOCG
ZW111: https://drive.google.com/drive/folders/152YhI17TDGtX6wI1UvALbLdHL6ZlcsFw
ZW101: https://drive.google.com/drive/folders/1vSlF8b2zq1eI6UpXk3Jh3JKzu5nJ_RYs
Fingerprint identification module is used for user's identity determination, when the user touches the fingerprint identification module with his/her finger, the fingerprint identification module will scan the user's fingerprints, and the algorithm chip can obtain the fingerprint image data for registration and comparison operation. This product is suitable for various applications that require fingerprint identification.
Parameters
Technical indicators
Item | Parameter |
Storage | 100 fingerprint data as standard |
Sensor type | Capacitive touch sensor |
Resolution | 508DPI |
FRR. | <3% |
FAR. | <0.001% |
Fingerprint sensor shape | orbicular |
Image gray level | 8-bit grayscale |
Service life | million times |
Static electricity test | Contact discharge ±8KV/Air discharge ±15KV |
Data interface | UART (TTL level) |
Sensor surface hardness | 3H |
Working temperature and humidity range | -25℃~+70℃; 45%~85%RH |
Storage temperature and humidity range | -40℃~+85℃; 45%~95%RH |
Mechanical characteristics
Project | Description | Unit |
Dimensions | Φ14mm | mm |
Ribbon | 5.6*4.8 | mm |
Resolution ratio | 112*96 | mm |
Electrical parameters
Item | Min | Typical | Max | Unit | |
Supply voltage | 3.0 | 3.3 | 3.6 | V | |
Standby current (sensor) | - | 10 | 12 | μA | |
Maping time | 50 | 60 | 70 | ms | |
Operating current (algorithm MCU) | 24 | 35 | 50 | mA | |
Eigenvalue generation time | 65 | 70 | 80 | ms | |
Comparison time | 130 | 600 | 1100 | ms | |
Power-on start time | - | 70 | 80- | ms | |
ESD rating | Non-contact discharg | - | 15 | - | KV |
Contact discharge | - | 8 | - | KV |
For more detail docs, please feel free to contact us.
