  3. Sensor Module
  5. Hi-link fingerprint recognition module HLK-ZW0608 square semiconductor capacitive fingerprint acquisition sensor switch module
    $5.15
Product Selection List
选型表 (1)
ZW0608-5
HLK-ZW0608 fingerprint module is a capacitive fingerprint recognition module. Consumers use fingerprint recognition modules for user identity determination. When the user touches the
fingerprint recognition module with their finger, the fingerprint recognition module will scan the user's fingerprint and then match it with the fingerprint database for determination.
The HLK-ZW0608 fingerprint module has functions such as fingerprint image processing, template extraction, template matching, fingerprint search and template storage.
Compared with similar fingerprint products, this fingerprint module has the following features:
Strong fingerprint adaptability
During the fingerprint image reading process, an adaptive parameter adjustment mechanism is adopted to achieve better imaging quality for both wet and dry fingers, and is applicable to a wider
range of people.
Simple to use and easy to expand
No fingerprint recognition expertise is required to apply. Users can develop powerful fingerprint recognition application systems by themselves according to the rich control commands
provided by the HLK-ZW0608 module.
Flexible setting of security levels
Users can set different security levels for different applications.
ZW0608-6
Application Scope
The HLK-ZW0608 module is widely used and suitable for all fingerprint recognition systems from low-end to high-end. like:
  • Door locks; more complex access control systems;
  • Fingerprint IC card identification terminal;
  • Fingerprint recognition and authentication system connected to PC.
Users can develop a variety of fingerprint recognition-based application systems according to the technical information provided in this manual.
Specifications
Conventional Technology Parameter
Serial number
Item Technical Parameters
1Module size19*19mm
2Sensor size12.05*12.05mm
3Resolution508dpi
4Number of pixels 160*160pixel
5Data ConnectionsUSART
6Interface Protocol RS232 (TTL)
7
Serial communication baud rate
Default baud rate 57600bps, 1 start bit, 1 stop bit, 3.3V TTL level
8
Interface and line sequence
6pin, 1.25mm horizontal sticker, please refer to the actual picture for the wiring sequence.
9
Fingerprint database capacity
100pieces
10
Storage temperatureand humidity
-40℃~+85℃; 45%~95%RH
11
Operating temperature and humidity
-25℃~+85℃; 45%~85%RH
12False recognition rate<0.001%
13Rejection rate<=1%
14Comparison method1 :N
15
After initialization is completed, a handshake command is actively sent.
support
16Self-learning functionnone
17
Fingerprint unique serial number
support
18
Fingerprint entry buffer definition
160*160 fingerprint head: bufferCharBuffer1, CharBuffer2 or CharBuffer3 are 0x00, 0x01, 0x02
respectively
19
Instructions use buffer definition
support
20
Fingerprint head security level
Default is level 3
21
Sensor solutionSensor wake up
Sleep command reliability
It is recommended that the lock end issues a sleep command during the process to support active sleep of the module.sensor
Sensor scan timeDefault 200ms
Quiescent Current
Average current 9-10uA
Output level
It is usually high level, and outputs low level when your finger touches the fingerprint sensor.
22
HBS system identification code
According toHBS communication protocol, the system identification code in the read system parameters (ReadSysPara) is defined according to the HBS assigned identification code, which facilitates the lock terminal to
identify the fingerprint head type.
23
Module version number
hardware version:HLK-ZW0608-V1.0
Software version:G1.10.4
24
Three-proof paint application requirements
1. Press HBS Engineering Department defines and implements the specifications, which requires the thickness to be greater than 0.05mm and the coating to be even.
2. Whole lock 96After H salt spray, the fingerprint head does not appear abnormal (such as functional failure or abnormal power consumption).
25
ESD requirements:
Contactdischarge: ±8KV
Air discharge: ±15KV
HBS static electricity requirements:
1. The fingerprint head needs to be subjected to two types of contact discharge and air discharge, with at least 6 groups of each voltageAfter x10 discharges, there should be no functional failure or abnormal power
consumption.
2. The number of test samples is required to be greater than 5pcs
25
Inspection report of the third police station
Support authentication
27Technical standard
satisfyGA701-2007/GA374-2019 standard, including anti-radiation interference capability
diagram
