  4. 79G radar sensor module
  5. 80G liquid water level detection sensor module HLK-LD8001H radar module non-contact, low-power, long-distance, high-precision
    $44.60
LD8001H-2
HLK-LD8001H radar sensor is a radar module designed specifically for hydrological detection. This module adopts FMCW mode, non-contact installation design, compact size, and compact structure. High precision, low power consumption, strong anti-interference ability, suitable for water level monitoring in lakes, rivers, mountain flood warning, reservoirs, sewage pipelines, etc
Measurement.
Specifications
① Functional parameters
ParametersSymbolMinTypicalMaxUnit  Illustrate
Transmitter
Transmission frequencyf77
81GHzBroadband 4G
Output Power (EIRP)
Pout
1320dBm
Antenna angle (refer to Figure 4)
Beam width (-3dB)
horizontal direction
±25bpm
vertical direction1±25Min
Beam width (-3dB) external lens antennahorizontal direction 1±3
vertical direction
±3
Power
working voltageVCC3.53.75V
working currentLCC
30
mA
typical
 value
OutputUART output, default baud rate 115200, ASCII/Modbus protocol can be freely switched
Environment
Operational temperatureTOP﹣45
+ 85
Module size35 x 35 x 1.2 mm
weight5 g
Measurement indicators
Ranging range0.15~40m
measurement accuracy±5mm
resolution ratio1mm
Start TimeFastest 100ms
Explanation:
The working frequency band of the radar is 80GHz, and the maximum measurement range is 40 meters. Depending on the size of the object's RCS, the maximum detection distance will be there is a deviation.
Hardware description
                                       LD8001-SIZE (1)
Application
详情-application
