  4. AC DC 15W
  5. AC-DC HLK-15M24C 15W 220V to 5V9V12V15V24V voltage reduction isolation switch power supply module stabilizing EMC circuit
    $2.58
15WC: https://drive.google.com/drive/folders/1vnVfcgQH-OvujpO6asvQvjIgmwUS2Pti
1. Ultra-small Series Power Module
The 15W ultra-small series module power supply is a small-volume, high-efficiency AC DC power module
supply designed by Shenzhen Hi-Link Electronics Co.,Ltd. It has the advantages of global input voltage range, low
temperature rise, low power consumption,high efficiency, high reliability and high safety isolation. It has been
widely used in smart home, automation control, communications equipment, instrumentation and other industries.
2. Product Model
ModelSize(mm)Output Power(W)Output Voltage(V)Output Current(mA)Notes
HLK-15M05C
       47.5*28.5*22
1553000
HLK-15M09C1591660
HLK-15M12C15121250
HLK-15M15C15151000
HLK-15M24C1524625
3. Product Features
2. Global universal input voltage (85~265Vac)
3. Low power consumption, green environmental protection, no-load loss<0.1W
4. Low ripple, low noise
5. Electrical characteristics
5.1. Input Features
Items
Technical ParametersUnitsNotes
Rated Input Voltage100-240 Vac
Input voltage range85-265 VacOr 120-350Vdc
The maximum input current
≤0.4 A
Input inrush current≤34 A
Input low start ≤50 mS
Long-term reliabilityMTBF≥100, 000 h
External fuse recommended
1A/250Vac
Slow blow
Note: Tested at room temperature
