AC-DC HLK-15M12C 15W 220V to 5V9V12V15V24V voltage reduction isolation switch power supply module stabilizing EMC circuit
Visitor1363
Price$2.25
1. Ultra-small Series Power Module
The 15W ultra-small series module power supply is a small-volume, high-efficiency AC DC power module
supply designed by Shenzhen Hi-Link Electronics Co.,Ltd. It has the advantages of global input voltage range, low
temperature rise, low power consumption,high efficiency, high reliability and high safety isolation. It has been
widely used in smart home, automation control, communications equipment, instrumentation and other industries.
2. Product Model
Model | Size(mm) | Output Power(W) | Output Voltage(V) | Output Current(mA) | Notes |
HLK-15M05C | 47.5*28.5*22 | 15 | 5 | 3000 | |
HLK-15M09C | 15 | 9 | 1660 | ||
HLK-15M12C | 15 | 12 | 1250 | ||
HLK-15M15C | 15 | 15 | 1000 | ||
HLK-15M24C | 15 | 24 | 625 |
3. Product Features
2. Global universal input voltage (85~265Vac)
3. Low power consumption, green environmental protection, no-load loss<0.1W
4. Low ripple, low noise
5. Electrical characteristics
5.1. Input Features
Items | Technical Parameters | Units | Notes |
Rated Input Voltage | 100-240 | Vac | |
Input voltage range | 85-265 | Vac | Or 120-350Vdc |
The maximum input current | ≤0.4 | A | |
Input inrush current | ≤34 | A | |
Input low start | ≤50 | mS | |
Long-term reliability | MTBF≥100, 000 | h | |
External fuse recommended | 1A/250Vac | Slow blow |
Note: Tested at room temperature
