Fingerprint recognition module HLK-FPM093D capacitive semiconductor touch fingerprint door lock acquisition sensor Test Kit
Visitor1178
Price$8.75
1.Summary
HLK-FPM093D is a new type of face-array semiconductor fingerprint module, which has the advantages of small size, low power consumption, fast recognition
speed, high recognition accuracy and so on, compared with the existing products in the market.
The HLK-FPM093D module is easy to use and is especially suitable for applications in smaller, battery-powered devices such as door locks, card readers, and safes,
where low power consumption maintains excellent responsiveness and high recognition speed.
This module adopts capacitive fingerprint sensor, which can effectively detect the problem of fake finger by measuring the fingerprint signal. The surface of the
fingerprint sensor uses a high hardness coating, which can greatly reduce the wear and tear on the fingerprint sensor in daily use. In addition, HLK-FPM093D can
withstand 15KV static electricity, which is not easy to damage the fingerprint sensor when used in winter or in the north and other areas where static electricity
is relatively high.
The HLK-FPM093D module uses a 1.0mm connector that can be connected using ordinary cables for enhanced connection reliability.
HLK-FPM093D interface supports UART, the default baud rate of UART is 57600. you can set the baud rate by software. (Note: The baud rate takes effect
immediately after it is set successfully, please use the new baud rate to communicate. If you forget the set baud rate, please return to the factory to reset or
verify all baud rates that may have been set.)
2.Characteristic
Sweden FPC1021 (160*160 resolution) face array fingerprint sensor
Sensor surface covered with protective coating
RGB tri-color LED lights
UART interface
1.0mm connector to support reliable connections
Fingerprint module supports 3.3V power supply
ESD Protection Rating >15KV
Supports storage of 100 fingerprint features (spliced 6 times)
3.Algorithm Specifications
Recognition rate FAR(FalseAcceptanceRate):<1/1000000
Reject rate FRR(FalseRejectionRate):<1%
Response speed: feature extraction time <0.25s , Single match time <0.002s
Support fingerprint splicing, maximum number of splicing: 6 times
Number of fingerprints: 100 fingerprints (spliced 6 times
4.Application Scenario
Security field: fingerprint door locks, safes, jewelry boxes
Management area: licensing, management software, etc.
Financial and other identity authentication fields: access control systems, POS machines, time and attendance machines, etc.
