Hi-link BLE5.0 Wireless Bluetooth Module HLK-B26 Master-Slave Integrated Serial Port Transmission Support APP Low Power Consumption
Visitor4430
Price$0.55
HLK-B26 is a BLE5.0 master-slave integrated Bluetooth serial port transmission module developed and produced by Hi-link Electronics. Various devices with serial ports can use Bluetooth wireless data transmission and reception simply and quickly through this module.
This product can be set to be used as a Bluetooth slave or host device. The host mode supports connecting one slave, and the slave mode supports connecting up to one host.
By using the serial Bluetooth bidirectional transmission function of this module, users do not need to understand the complex Bluetooth protocol stack. They only need to connect the customer's device or MCU's serial port to this module, and the module will automatically complete the bidirectional data forwarding between the serial port and Bluetooth (GATT), which is like a bridge between the user's MCU serial port and Bluetooth device, adding Bluetooth wireless transmission function to the user's serial device. Supports AT command mode, which allows for querying or setting basic parameters of the module, such as device name, serial port baud rate, etc., through serial port AT commands. This module provides rich testing tools and user documentation, including a mobile app demo, making it easy for users to quickly become familiar with and apply this module.
The schematic diagram of the Bluetooth serial port transparent function is as follows:
Product characteristics
Main frequency 96MHz, 32bit
Fast and stable Bluetooth serial port transmission, with a baud rate of up to 921600
Master slave integrated Bluetooth, can be set to either master or slave mode
Support custom broadcast data
Based on BLE5.0, it has faster speed, longer transmission distance, and can reach up to 50m in open environments
Supports low-power mode with a sleep current of 102 μ A. Support custom connections and broadcast intervals
Bluetooth transmission power adjustable, up to 8dBm, receiving sensitivity up to -92dBm
Support OTA Bluetooth wireless upgrade module firmware, wireless configuration module parameters
Default onboard antenna, extremely low-cost control, with strong wireless signal under low-cost conditions
Built in Watchdog for reliable long-term operation
Wide working voltage of 1.8V to 3.4V, typical value of 3.0V
Application scenarios
The serial Bluetooth bidirectional transparent transmission provided by HLK-B26 provides a simple and flexible data channel, which can be widely used in various products that require wireless data transmission through Bluetooth.
Common application scenarios are as follows:
Smart Home/Home Appliances
Control smart sockets, smart lights, smart door locks, etc. through mobile phones
Internet of Things
Wireless data transmission between mobile phones and devices, devices and devices
Instrumentation
Reading data and configuring parameters wirelessly through Bluetooth
Industrial and agricultural control
Connect various control or sensing devices wirelessly through Bluetooth for reading and control, etc
Medical health
Health data monitoring, wireless care devices, etc
Automotive Electronics
Wireless detection and control, etc
Toy entertainment
Bluetooth remote control, wireless control and transmission
More possibilities await you to unlock
Welcome to contact us.
