AC/ DC 15v 40w GaN Step Down mini Power Supply Module Converter Intelligent household switch power module HLK-40M15
Visitor2448
Price$6.98
GNS-Gallium Nitride Solution
Working Temerature -25—+60 ℃
Storage temperature -40—+80 ℃
Relative humidity 5—95 %
Altitude ≤2000 m
The maximum input current ≤0.9A
Input inrush current ≤34A
Input low start ≤50mS
External fuse recommended 2A/250Vac or 10Ω wire wound resistance, Slow blow
Full-load rated output voltage 15.0±0.2%
Load regulation ±0.5%
Ripple/Noise ≤70mVp-p(Typ:50)
Meet UL/CE requirements
