5G Wireless WiFi Module 5G module+MT7612E+MT7621 Dual Band Gigabit Wireless Network Card Linux System Development Board
Visitor2360
Price$166.00
For hardware docs, please feel free to contact us.
Brief Introduction
HLK-7612E use a highly integrated single chip which has built in a 2x2 dual-band wireless LAN radio. It supports IEEE802. 11ac draft standard and provides the highest PHY rate up to 867Mbps, offering feature-rich wireless connectivity and reliable throughput from an extended distance. Optimized RF architecture and baseband algorithms provide superb performance and low power consumption. MT7612E integrates PA/LNA such that the number of the external components is reduced to minimum. Intelligent MAC design deploys a highefficient DMA engine and hardware data processing accelerators which offloads the host processor. The MT7612E supports the 802.11i security standard and implements hardware acceleration for TKIP, CCMP and WAPI. The device also supports 802.11e QoS for video, voice, and multimedia applications.
The HLK-7621 module use the MT7621A chipset.The MT7621A integrates aual-core MIPS-1004Kc (880MHz), HNAT/HQoS/Samba/VPN accelerators, 5-port GbE switch, RGMII, USB3.0, USB2.0, 3xPCIe, SD-XC. The powerful CPU with rich portfolio is suitable for 802.11ac, LTE cat4/5, edge, hotspot, VPN,AC (Access Control). It can also connect to touch-panel, ZigBee/Z-Wave for Internet Service Router and Home Security Gateway.
For the next generation router, MT7621A provides several dedicated hardware engines to accelerate the NAT, QoS, Samba and VPN traffic.These accelerators relief the CPU for other upper layer applications.
7621 Features
Embedded MIPS1004Kc (880 MHz, Dual-Core)
- 32 KB I-Cache and 32 KB D-Cache per core
- 256 KB L2 Cache (shared by Dual-Core
- SMP capable
- Single processor operation configurable
Gigabit Switch
- 5 ports with full-line rate
- 5-port 10/100/1000Mbps MDI transceivers
One RGMII/MII interface
16-bit DDR2/3 up to 256/512 Mbytes
SPI(2 chip select), NAND Flash(SLC), SDXC,eMMC(4 bits)
USB3 x 1+ USB2 x 1 or USB2 x 2 (all host)
PCIe host x 3
I2C, UART Lite x 3, JTAG, MDC, MDIO, GPIO
VoIP support (I2S, PCM)
Audio interface (SPDIF-Tx, I2S, PCM)
Deliver the superb Samba performance via USB2.0/USB 3.0/SD-XC
HW storage accelerator
HW NAT
- 2Gbps wired speed
- L2 bridge
- IPv4 routing, NAT, NAPT
- IPv6 routing, DS-Lite, 6RD, 6to4
HW QoS
- 16 hardware queues to guarantee the min/max bandwidth of each flow.
- Seamlessly co-work with HW NAT engine.
- 2Gbps wired speed.
HW Crypto
Deliver 400~500 Mbps IPSec throughput
Green
-Intelligent Clock Scaling (exclusive)
-DDR2/3: ODT off, Self-refresh mode
Firmware: Linux 2.6 SDK, OpenWRT
RGMII iNIC Driver: Linux 2.4/2.6
Brief Introduction
7612E Block Diagram
7612E Specifications
Specifications | |
Chipset | MTK MT7612E External PA/LNA/SWITCH: SKY85712-21 |
Interface | Normal Gold Finger miniPCIE 5.8G 2T2R 867Mbps 11ac 21dBm@A mode |
DC Power | 1x DC MINIPCIE Connector: 3.3V@1A 5V@1A |
Power Consumption | 3 Watt (Max) |
Software | OpenWRT or MTK Linux SDK Driver and Tool Chain |
Certification | Support CE & FCC, RoHS Compliant |
Environmental | Temperature: Operating: 0ºC -55 ºC, Storage: -40ºC to 90ºC Humidity (non-condensing): Operating: 5% to 95%, Storage: Max . 90% |
7612E RF Parameter
5G ITEM | RATE | Value |
A Mode Pwr (dBm) | 54M | 21dBm |
N HT20 Pwr (dBm) | MCS7:65M | 20dBm |
N HT40 Pwr (dBm) | MCS7:135M | 19dBm |
AC VHT80 Pwr (dBm) | MCS9:390M | 18dBm |
A Mode EVM (dB) | 54M | 三-26dB |
N HT20 EVM (dB) | MCS7:65M | 三-28dB |
N HT40 EVM (dB) | MCS7:135M | 三-28dB |
AC VHT80 EVM (dB) | MCS9:390M | 三-32dB |
FeqErr (ppm) | Test with TX POWER test | ± 10ppm |
A RX sensitivity (dB) | 54M | -70dBm |
N HT20 RX sensitivity (dB) | MCS7:65M | -68dBm |
N HT40 RX sensitivity (dB) | MCS7:135M | -65dBm |
AC VHT80 RX sensitivity (dB) | MCS9:390M | -55dBm |
