HLK-7612E 5G Wireless Communication WiFi Module MT7612E Dual Band Gigabit Wireless Network Card Linux /Android System
Visitor4894
Price$8.00
Brief Introduction
HLK-7612E use a highly integrated single chip which has built in a 2x2 dual-band wireless LAN radio. It supports IEEE802. 11ac draft standard and provides the highest PHY rate up to 867Mbps, offering feature-rich wireless connectivity and reliable throughput from an extended distance. Optimized RF architecture and baseband algorithms provide superb performance and low power consumption. MT7612E integrates PA/LNA such that the number of the external components is reduced to minimum. Intelligent MAC design deploys a highefficient DMA engine and hardware data processing accelerators which offloads the host processor. The MT7612E supports the 802.11i security standard and implements hardware acceleration for TKIP, CCMP and WAPI. The device also supports 802.11e QoS for video, voice, and multimedia applications.
Block Diagram
Specifications
Specifications | |
Chipset | MTK MT7612E External PA/LNA/SWITCH: SKY85712-21 |
Interface | Normal Gold Finger miniPCIE 5.8G 2T2R 867Mbps 11ac 21dBm@A mode |
DC Power | 1x DC MINIPCIE Connector: 3.3V@1A 5V@1A |
Power Consumption | 3 Watt (Max) |
Software | OpenWRT or MTK Linux SDK Driver and Tool Chain |
Certification | Support CE & FCC, RoHS Compliant |
Environmental | Temperature: Operating: 0ºC -55 ºC, Storage: -40ºC to 90ºC Humidity (non-condensing): Operating: 5% to 95%, Storage: Max . 90% |
RF Parameter
| RATE | Value |
A Mode Pwr (dBm) | 54M | 21dBm |
N HT20 Pwr (dBm) | MCS7:65M | 20dBm |
N HT40 Pwr (dBm) | MCS7:135M | 19dBm |
AC VHT80 Pwr (dBm) | MCS9:390M | 18dBm |
A Mode EVM (dB) | 54M | 三-26dB |
N HT20 EVM (dB) | MCS7:65M | 三-28dB |
N HT40 EVM (dB) | MCS7:135M | 三-28dB |
AC VHT80 EVM (dB) | MCS9:390M | 三-32dB |
FeqErr (ppm) | Test with TX POWER test | ± 10ppm |
A RX sensitivity (dB) | 54M | -70dBm |
N HT20 RX sensitivity (dB) | MCS7:65M | -68dBm |
N HT40 RX sensitivity (dB) | MCS7:135M | -65dBm |
AC VHT80 RX sensitivity (dB) | MCS9:390M | -55dBm |
