  3. Communication Module
  4. WiFi Router Module
  5. Dual Band WiFi 6 Routing Module Gigabit AX3000 OpenWrt Gateway MT7981B+MT7976C+MT7531A Module Development Kit HLK-RM65
    $55.98
Download Files
Introduciton
HLK-RM65 is a high-performance embedded WIFI6 AX3000 module launched by Hi-Link Electronics, which is highly integrated the on chip system wireless network router module uses the MT7981B+MT7976C+MT7531A scheme, with a theoretical maximum wireless speed 574Mbps+2402Mbps. Used for high wireless performance, home entertainment, and home automation.
The SoC used is manufactured using advanced silicon technology and integrates dual core ARM ® Cortex-A53MPCoreTM, working up to 1.3GHz frequency and more DRAM bandwidth. It also includes various peripherals, including SGMII and USB3.0 (host) port. two 2.5Gbps HSGMII Ethernet interfaces have also been implemented. MT7981B, combined with RF chips, can provide
the WIFI6 AX3000 wireless router platform provides a dual frequency concurrent chipset solution.
Packing list
  1. HLK-RM65 module*1
  2. Development board*1
  3. Dual band antenna & connecting line*5
  4. 12v1a input adapter*1
Features
  • Power (2.4GHz and 5GHz) MIMO 802.11 A/B/G/N/AC/AX RF, power 20/40/80/160MHz
  • Flash/DDR3 expansion contains DDR3/DDR4-2133 2GB/4GB
  • Power: 2.4-2.4835GHz 5.180-5.885GHz
  • Chengdu 2.4GHz/5GHz PA, LNA
  • Cable connection method: I-PEX generation 1
  • Mouth wan. lan1. lan2. lan3. lan4. lan5. usb3.0;
  • Wide area network access PPPoE, mobile IP, IP, 3G/4G/5G
  • Static address configuration, virtual server configuration, port forwarding DMZ
  • Organization name: DC3.3V5A
Diagram
Technical Specifications
ModelModeHLK-RM65
Wireless
parameters
Wireless
standards
2.4-2.4835GHz5.180-5.885GHz
Transmitting
power
802.11b: +23±1.5dBm (11M)802.11a: +20±1.5dBm (54M)
802.11g: +20±2dBm (54M)802.11n(20M): +18±2dBm (MCS7)
802.11n(20M): +19±2dBm (MCS7)802.11n(40M): +18±1.5dBm (MCS7)
802.11n(40M): +19±1.5dBm (MCS7)801.11ac(20M):+17.5±2dBm (MCS9)
801.11ac(20M):+17±2dBm (MCS9)801.11ac(40M):+17.5±1.5dBm (MCS9)
801.11ac:(40M)+17±1.5dBm (MCS9)801.11ac(80M):+17.5±1.5dBm (MCS9)
802.11ax(20M): +17±1.5dBm (MCS11)802.11ax(20M): +17±1.5dBm (MCS11)
802.11ax(40M): +16.5±1.5dBm (MCS11)802.11ax(40M): +17±1.5dBm (MCS11)
802.11ax(80M): +17±1.5dBm (MCS11)
802.11ax(160M): +15.5±1.5dBm (MCS11)
Receiver sensitivity
Unit:dBmch1ch6ch13unit:dBmch50ch114ch163
2G BW20: (MCS0) --93.5-93.5-93.55G BW20: (MCS0)-92.5-92.5-92.5
2G BW20:(MCS7)-74.5-74-745G BW20:(MCS7)-73.5-73.5-73.5
2G BW20: (MCS9)-68.5-68-685G BW20: (MCS9)-68-68-68
2G BW20: (MCS11)-63-63-63.55G BW20: (MCS11)-62-62-62
2G BW40: (MCS0)-90.5-90.5-90.55G BW160: (MCS0)-83-83-83
2G BW40: (MCS7)-71.5-71.5-71.55G BW160: (MCS7)-64.5-64.5-64.5
2G BW40: (MCS9)-65.5-65.5-65.55G BW160: (MCS9)-58.5-59-59
2G BW40: (MCS11)-60-60-605G BW160: (MCS11)-53-53.5-53.5
Antenna formExternal: I-PEX first generation antenna base * 5
Hardware parameters
StorageDDR3: 256M(2Gbit); Nand Flash: 128M(1Gbit)
Hardware portUART,GPIO, SPI,USB,PWM
Ethernet portGigabit Ethernet port * 6: WAN * 1, LAN * 5
USBPartial foot multiplexingUSB3.0*
PCIePCIe*1
SGMII2.5G SGMII*1
Working voltage3.3V
Working currentContinuously sending=>Average: 2.8A@3.3V (It is recommended to have a 3.3V power supply capacity of over 5A)
In normal mode=>Average: 1.27A@3.3
IO drive capabilityVMax:12ma
TemperatureWorking temperature:-20℃~80℃
Passage size60*90mm
Storage temperatureTemperature: -40~+85 ℃, relative humidity: 5% -90% RH (non condensing)
Software parametersWireless network typeSTA/AP/APClient
Upgrade commandWeb page upgrade, command network port upgrade
Network protocolIPv4, TCP/UDP
Software environmentOpenwrt
User profileWeb page configuration
Product pictures
Electrical parameters
ParameterMintypicalMaxUnit
Module supply voltage3.13.33.5V
Chip supply voltage3.13.33.5V
I/O voltage3.13.33.5V
Module average power consumption4.0
W
Module current peak2.8
Power supply current requirements
≥5
Power supply ripple requirements
≤50
mV
ESD contact discharge
±2
KV
ESD non-contact discharge
±2
KV
