  4. DC DC 1W
  5. B1205LS/B1212LS/B1215LS/B1224LS-1WR3 12V to 5V/12/15/24 1W DC to DC Isolated constant voltage input non stabilized single output power module
    $0.64
加水印 B05XXLS-1WR3 Series Mode list
2. isolation voltage≤1500VDC
4. Low ripple, low noise
Storage temperture-40—+80 ℃
Items Working conditionsMin.Typ.Max.Unit
Input current
(fully loaded/
unloaded)
3.3VDC Input--378/6--/12mA
5VDC Input--224/5--/10
12VDC Input--93/3--/5
15VDC Input--74/2--/4
24VDC Input--47/1--/2
Reflected Ripple Current4.5--15--mA
Impulse voltage (Isec.max)3.3VDC Input-0.7--5VDC
5VDC Input-0.7--9
12VDC Input-0.7--18
15VDC Input-0.7--21
24VDC Input-0.7--30
Capacitive filtering
Hot plug
Not available
Output Characteristics(15v/±34mA)
ItemsWorking and test conditions Min.Typ.Max. Unit
Output loadLoad percentage 10--100%
Output VoltageAccuracyRefer to Error Envelope Curve ----±15.0%
Linear adjustment rate
Input voltage
variation ±1%
3.3V Output----±1.5%
Others----±1.2 %
Load Regulation
10%~100%
Load
3.3VDC Output --1812%
5VDC Output --12
9VDC Output --8
12VDC Output --7
15VDC Output --6
24VDC Output--5
Ripple & Noise
Pure resistive load, 20MHz bandwidth,
peak-to-peak
--3080mVp-p
Temperature Drift CoefficientFull load --
--±0.03%/°C
Note: ①The test method of ripple and noise is twisted pair test method.
1. General application:
