B0505LS-1WR3 power module 5V to 5V 1W 200mA DC to DC Isolated constant voltage input non stabilized single output
Visitor4624
Price$0.42
5W: https://drive.google.com/drive/folders/13pTx02uL4moskJ-PQsBYFytdq2pPt2mN
2. isolation voltage≤1500VDC
4. Low ripple, low noise
Items | Working conditions | Min. | Typ. | Max. | Unit |
Input current (fully loaded/ unloaded) | 3.3VDC Input | -- | 378/6 | --/12 | mA |
5VDC Input | -- | 224/5 | --/10 | ||
12VDC Input | -- | 93/3 | --/5 | ||
15VDC Input | -- | 74/2 | --/4 | ||
24VDC Input | -- | 47/1 | --/2 | ||
Reflected Ripple Current | 4.5 | -- | 15 | -- | mA |
Impulse voltage (Isec.max) | 3.3VDC Input | -0.7 | -- | 5 | VDC |
5VDC Input | -0.7 | -- | 9 | ||
12VDC Input | -0.7 | -- | 18 | ||
15VDC Input | -0.7 | -- | 21 | ||
24VDC Input | -0.7 | -- | 30 | ||
Hot plug | Not available |
Output Characteristics(15v/±34mA)
Items | Working and test conditions | Min. | Typ. | Max. | Unit | |
Output load | Load percentage | 10 | -- | 100 | % | |
Output VoltageAccuracy | Refer to Error Envelope Curve | -- | -- | ±15.0 | % | |
Linear adjustment rate | Input voltage variation ±1% | 3.3V Output | -- | -- | ±1.5 | % |
Others | -- | -- | ±1.2 | % | ||
Load Regulation | 10%~100% Load | 3.3VDC Output | -- | 18 | 12 | % |
5VDC Output | -- | 12 | % | |||
9VDC Output | -- | 8 | % | |||
12VDC Output | -- | 7 | % | |||
15VDC Output | -- | 6 | % | |||
24VDC Output | -- | 5 | % | |||
Ripple & Noise | Pure resistive load, 20MHz bandwidth, peak-to-peak | -- | 30 | 80 | mVp-p | |
Temperature Drift Coefficient | Full load | -- | -- | ±0.03 | %/°C | |
Note: ①The test method of ripple and noise is twisted pair test method. |
1. General application:
For more module mode, please feel free to contact Hi-link team.
