MT7628N Ethernet Wifi Wireless Router module with OpenWrt Firmware RAM64MB FLASH 8MB HLK-7628NE
Visitor6905
Price$5.80
First time to test, Please click this link for the kits, including the module, test board, antenna and adapter, which will speed up your development.
https://www.hlktech.net/index.php?id=435
Introduciton
HLK-7628NE(RAM64MB FLASH 8MB) based on MT7628AN is a low cost and low power consumption IOT module developed by Hi-Link. This module leads to all the interfaces of MT7628NN,The module supports Linux, OpenWRT operating system and custom development. It could be widely applied to smart devices or cloud services application with its rich interface and powerful processors, at the same time ,it also support secondary development.
Features
High data processing ability,MCU frequency 580MHz
300M Mbps
Support 802.11b/g/n
20/40 Channel bandwidth
Support 802.11v
Support AP,STA and AP,STA mixed
Five 10/100M ETH PORT
1 USB2.0 Host interface port
Interface SPI/SD-XC/eMMC
Rich peripheral interfaces,SPI,I2C,I2S,PCM,UART,JTAG,GPIO
Widely used in IOT
Inbuilt powerful PMU
Support 16 Multiple BSSID
Support multiple security methods WEP64/128, TKIP,AES, WPA, WPA2, WAPI
Support QoS,WMM,WMM-PS
Support Linux 2.6.36 SDK,OpenWrt 3.10
Diagram
Typical Application
Specifications
Item | Parameter | Note |
Model | HLK-7628N | Version V1.0 |
Chip | MT7628AN/MT7628NN | |
Kernel | MIPS24KEc | |
Basic frequency | 580MHz | |
RAM | DDR2 64MB | |
Flash | 8MB | |
Temperature | Environment temperature:-40℃~85℃ | |
Humidity | Working:10~95%(noncondensing) Storage:5~95%(noncondensing) | |
Size | 18mm×35.2mm×2.8mm |
Module Dimension Chart
