HLK-5M05 AC to DC 5v 5w Step Down mini Power Supply Module Converter Intelligent household switch power module
Visitor6530
Price$1.55
Global universal input voltage(90-264VAC)
Working Temerature -25—+60 ℃
Storage temperature -40—+80 ℃
Relative humidity 5—95 %
Altitude ≤2000 m
Vibration coefficient 10~500Hz,2G10min./1cycle, 60min.each along X,Y,Z axes. Meets secondary road transportation requirements
The maximum input CURRENT ≤0.2A
Input inrush current ≤10A
Input low start ≤50mS
Long-term reliablity MTBF≥100000H
Full-load rated output voltage 5.0±0.2%
Load regulation ±0.5%
Switching on/off overshoot amplitude 5mS(115VAC/60mS,220VAC)
Output over-current protection Output maximum load 110-150% A
Ripple/Noise ≤100mVp-p(Typ:50)
