  4. AC DC 30W
  5. Lower price AC to DC 24v1.5a 30w Step Down Converter Intelligent household switch power module HLK-30M24C
    $3.15
product list
Brief Introduction
The 30W ultra-small series module power supply is a small, high-efficiency power supply module designed by Hi-link Electronics for customers. It has the advantages of global input voltage range, low temperature rise, low power consumption, high efficiency, high reliability, and high safety isolation. It has been widely used in industries such as smart home, automation control, communication equipment, and instrumentation.
2. Global universal input voltage (90~265Vac)
3. Low power consumption, green environmental protection, no-load loss<0.2W 4. Low ripple, low noise
Storage temperture-40—+80 ℃
Related input voltage100-240Vac
Input voltage range85-264Vdcor 120-350V dc
Maximum input current≤0.7A
Input inrush current≤50A
Input low start≤50mS
Long-term reliabilityMTBF≥100000H
external fuse recommended2A/250VacVdcSlow blow
No load rated output voltage5V±0.1Vdc
Full load rated output voltage5V±0.2Vdc
Short-time maximum output current≥6100mA
Rated output current6000mA
Voltage regulation±0.2%
Load regulation ±0.5%
Input low voltage efficiencyVin=115Vac, output full load ≥85%
Input high voltage efficiencyVin=230Vac, output full load ≥87%
Output ripple and noise (mVp-p)≤100 Pure resistance load, 20MHz bandwidth,Load side 10uF and 0.1uF capacitance testmV
Switching on/off overshoot amplitude
(Rated input voltage, output plus 10% load)≤5%Vo
Output over-current protectionOutput maximum load 110-150%A
Output short circuit protectionDirect short circuit in normal output and automatic return to normal operation after removal of short circuit
No-damage to the whole device
Output Characteristics(9V/3300mA)
No load rated output voltage9V±0.1Vdc
Full load rated output voltage9V±0.2Vdc
Short-time maximum output current≥3400mA
Rated output current3300mA
Voltage regulation±0.3%
Input low voltage efficiencyVin=115Vac, output full load ≥86%
Output Characteristics(12V/2500mA)
No load rated output voltage12V±0.1Vdc
Full load rated output voltage12V±0.2Vdc
Short-time maximum output current≥2600mA
Rated output current2500mA
Voltage regulation±0.4%
Output Characteristics(15V/2000mA)
No load rated output voltage15V±0.1Vdc
Full load rated output voltage15V±0.2Vdc
Short-time maximum output current≥2100mA
Rated output current2000mA
Output Characteristics(24V/1250mA)
No load rated output voltage24V±0.1Vdc
Full load rated output voltage24V±0.2Vdc
Short-time maximum output current≥1350mA
Rated output current1250mA
FuseProtest the circuit from damage when the module is abnormal2A/250Vac, Slow fuse
VaristorThe cumulative surge is to protect the module from damage10D561K
C1/Safety capacitance Filtering, safety protection(EMC certification) 0.1uF/275Vac
L1/Common-mode inductanceEMI filteringSensible value 10-20mH, current 1-2A
1234
ACACVO-VO+
Dimension error:
  1. Length, width, height and lead pitch error ±8%
  2. Lead length error ±1mm
  3. Lead diameter error ±0.2mm
  4. Weight ≤80g
