  4. AC DC 3W
  5. HLK-PM24 AC to DC 24v 3w Step Down mini Power Supply Module Converter Intelligent household switch power module
    $1.55
产品型号-3
Working Temerature   -25—+60 ℃
Storage temperature       -40—+80 ℃
Relative humidity     5—95 %
Altitude ≤2000 m
Vibration Vibration coefficient 10~500Hz,2G10min./1cycle, 60min.each along X,Y,Z axes Meets requirements for secondary road transportation
Rated input voltage        100-240Vac
Input vlotage range         85-264VAC/70-350VDC
The maximum input voltage             270VAC
The maximum input CURRENT        ≤0.1A
Input inrush current                         ≤10A
Input low start                                 ≤50mS
Input voltage efficiency                   ≤69%/70%(110/220VAC)
External fuse recommended           1A/250Vac or 10Ω wire wound resistance, Slow blow
Full-load rated output voltage          24±0.2%
Load regulation                                     ±0.5%
Switching on/off overshoot amplitude                5mS(115VAC/60mS,220VAC)
Output over-current protection Output maximum load             110-150% A
Ripple/Noise                   ≤70mVp-p(Typ:50)
Meet UL/CE requirements
