24V to 15V 20W 1333mA DC to DC 91% transfer input power supply converter/module URB2415YMD-20WR3
Visitor433
Price$7.05
1. Ultra wide range input (4:1), output 20W
Maximum input current | ≤2.3 | A | |
Reflection ripple current | 40 | mA | DC12V rated input voltage series |
Output Characteristics(15V/1333mA)
No load rated output voltage | 15V±2% | Vdc | |
Short-time maximum output current | ≥1433 | mA | |
Rated output current | 1333 | mA | |
Load regulation | ±1 | % | |
Transfer efficiency | Vin=24Vdc, output full load 90 | % | |
MOV/Varistor | Protest the circuit from damage when the module is abnormal | 14D560K |
LDM1/Common mode inductance | EMI Filtering | Inductance: 10mH |
1 | 2 | 3 | 4 | 5 | 6 |
VIN- | VIN+ | VO+ | TRIM | GND | CTRL |
Input negative | Input positive | Output positive | Voltage regulator | Output negative | Remote end |
