  4. DC DC 10W
  5. URA2405LD-10WR3 URA2412/ URA2424 DCDC isolated power module 24 to 3.3/9/12/15/24V wide voltage input power converter
    $4.76
URA_LD-10WR3 Series Mode list 拷贝
1. Wide input voltage range 2:1, isolated regulated output 10W
3. Transfer efficiency up to 86%
4. Ultra-long standby power consumption 0.3W(Typle)
5. Quick Start:100mS(Typ)
9. Output short-circuit protection: continuous short circuit protection, automatic recovery
ItemWorking conditions
Min.Typ.Max.Unit
Input current(fully load/no-load)12VDC Input Series3.3V Output-714/25733/42
5.0V Output-1067/251096/42
12.0V Output-845/25867/42
15.0V Output-1003/251028/42mA
24.0V Output-911/251015/42
24VDC Input Series3.3V  Output-357/13366/21
5.0V Output-533/13548/21
12.0V Output-423/13434/21
15.0V Output-502/13514/21
24.0V Output-455/13508/21
48VDC Input Series3.3V  Output-179/7183/11
5.0V Output-267/7274/11
12.0V Output-212/7217/11
15.0V Output-251/7257/11
24.0V Output-228/7148/11
110VDC Input Series3.3V Output-78/380/2
5.0V Output-116/3119/5
12.0V Output-109/3111/5
15.0V Output-209/3214/5
24.0V Output-105/3107/5
Reflected Ripple Current12VDC Input Series--60--mA
24VDC Input Series--40--
48VDC Input Series--30--
110VDC Input Series--20--
Impulse voltage  (Isec.max)12VDC Input Series-0.7--30VDC
24VDC Input Series-0.7--50
48VDC Input Series-0.7--10
110VDC Input Series-0.7--20
110VDC nominal input series, nominal input voltage--72
Input under-voltage protection24VDC nominal input series, nominal input voltage---
48VDC nominal input series, nominal input voltage---
110VDC nominal input series, nominal input voltage----
Start timeNominal input voltage and constant resistance load-100--ms
PI Type
CNTCtrl*Module turned onCtrl dangling or TTL high level 3.5-12VDC
Module turned offCtrl Connect to GND or low level 0-1.2VDC
Input current at shutdown-01mA
Note: * The voltage of the Ctrl control pin is relative to the input pin GND, this series of products does not have this function.
-±1.0%±2.0%-±2.0%±3.0%
±2.0%±0.5%-±1.5%±2.0%
Load adjustment rate
20%~100% rate
load, balanced
±0.5%
±1.0%-±4.0%±5.0%
