48V to 12V 10W ±0.42 DC to DC Isolation Voltage 1500VDC Power Module Converter URA4812YMD-10WR3
Visitor1777
Price$5.15
1. Wide input voltage range 4:1, isolated regulated output 10W
4. Ultra-long standby power consumption 0.036W(Typle)
5. Quick Start:1mS(Typ)
9. Output short-circuit protection: continuous short circuit protection, automatic recovery
Input currency( full loaded/ Unloaded | 24VDC Input Series | 3.3V | - | 402/1 | 413/2 | mA |
others | - | 490/1 | 502/2 | |||
48VDC Input Series | 3.3V | - | 201/0.5 | 207/1 | ||
others | - | 245/0.5 | 251/1 | |||
110VDC Input Series | 3.3V | - | 87/0.3 | 90/0.5 | ||
others | - | 100/0.3 | 109/0.5 | |||
Reflected ripple current | 24VDC Input Series | -- | 40 | -- | ||
48VDC Input Series | -- | 30 | -- | |||
Impulse voltage (Isec.max) | 24VDC Input Series | -0.7 | -- | 50 | ||
Start voltage | 24VDC nominal input series, nominal input voltage | - | - | 9 | ||
48VDC nominal input series, nominal input voltage | - | - | 18 | |||
110VDC nominal input series, nominal input voltage | - | - | 40 | |||
Input undervoltage protection | 24VDC nominal input series, nominal input voltage | 5.5 | 6.5 | - | ||
110VDC nominal input series, nominal input voltage | 32 | 36 | - | |||
