  4. DC DC 10W
  5. URA1D05YMD-10WR3 URA1D12/URA1D24YMD DCDC isolated power module 110V to 3.3/9/12/15/24 dual output power converter
    $4.88
URA48_YMD-10WR3 Series Mode list
1. Wide input voltage range 4:1, isolated regulated output 10W
4. Ultra-long standby power consumption 0.036W(Typle)
5. Quick Start:1mS(Typ)
9. Output short-circuit protection: continuous short circuit protection, automatic recovery
Ripple & Noise50/80(max)
Mvp-p
ItemWorking conditions
Min.Typ.Max.Unit
Input currency( full loaded/ Unloaded24VDC Input Series3.3V-402/1413/2mA
others-490/1502/2
48VDC Input Series3.3V-201/0.5207/1
others-245/0.5251/1
110VDC Input Series3.3V-87/0.390/0.5
others-100/0.3109/0.5
Reflected ripple current24VDC Input Series--40--
48VDC Input Series--30--
110VDC Input Series--20--
Impulse voltage
(Isec.max)
24VDC Input Series-0.7--50
48VDC Input Series-0.7--100
110VDC Input Series-0.7--200
Start voltage24VDC nominal input series, nominal input voltage--9
-±1.0%±2.0%-±2.0%±3.0%
±2.0%±0.5%-±1.5%±2.0%
Load adjustment rate
20%~100% rate
load, balanced
±0.5%
±1.0%-±4.0%±5.0%
