  4. DC DC 6W
  5. URB2405ZP-6WR3/URB2409ZP/URB2412ZP/URB2415ZP/URB2424ZP 24V to 3.3V/5V/9V/12V/15V/24V 6W DC to DC Isolation Voltage Power Converter Module
    $3.55
URB48XXZP-6W Series Mode list
4. Ultra-long standby power consumption 0.036W(Typle)
5. Quick Start:1mS(Typ)
9. Output short-circuit protection: continuous short circuit protection, automatic recovery
Ripple & Noise50/80(max)
Mvp-p
ItemWorking conditions
Min.Typ.Max.Unit
Input currency( full loaded/ Unloaded24VDC Input Series3.3V-235/1241/2mA
others-294/1301/2
48VDC Input Series3.3V-118/0.5121/1
others-147/0.5151/1
110VDC Input Series3.3V-51/0.353/0.5
others-64/0.366/0.5
Reflected ripple current24VDC Input Series--40--
48VDC Input Series--30--
110VDC Input Series--20--
Impulse voltage
(Isec.max)
24VDC Input Series-0.7--50
48VDC Input Series-0.7--100
110VDC Input Series-0.7--200
Start voltage24VDC nominal input series, nominal input voltage--9
-±1.0%±2.0%-±2.0%±3.0%
±2.0%±0.5%-±1.5%±2.0%
Load adjustment rate
20%~100% rate
load, balanced
±0.5%
±1.0%-±4.0%±5.0%
