HLK-PM09 AC to DC 9v 3w Step Down mini Power Supply Module Converter Intelligent household switch power module
Visitor6008
Price$1.52
Working Temerature -25—+60 ℃
Storage temperature -40—+80 ℃
Relative humidity 5—95 %
Altitude ≤2000 m
Vibration Vibration coefficient 10~500Hz,2G10min./1cycle, 60min.each along X,Y,Z axes Meets requirements for secondary road transportation
The maximum input CURRENT ≤0.1A
Input inrush current ≤10A
Input low start ≤50mS
Input voltage efficiency ≤69%/70%(110/220VAC)
Full-load rated output voltage 9.0±0.2%
Load regulation ±0.5%
Switching on/off overshoot amplitude 5mS(115VAC/60mS,220VAC)
Output over-current protection Output maximum load 110-150% A
Ripple/Noise ≤70mVp-p(Typ:50)
Meet UL/CE requirements
