VRB0505S-6WR3,VRB1205S-6WR3,VRB2405S-6WR3,VRB4805S-6WR3 DC-DC 5V/12V/24V/48V to 5V/12V//15V24V isolated power module
Visitor6257
Price$2.74
1. Wide input voltage range 2:1, isolated regulated output 6W
4. Low ripple noise
7. No-load power consumption less than 0.12W
Ripple & Noise | 50/130(max) | Mvp-p |
Input voltage range(fully loaded/unloaded) | 12VDC Input Series | 3.3V output | - | 476/5 | 490/12 | mA |
5V output | - | 610/5 | 626/12 | |||
others | - | 602/5 | 620/12 | |||
24VDC Input Series | 3.3V output | - | 238/5 | 245/12 | ||
5V output | - | 305/5 | 313/12 | |||
others | 301/5 | 310/12 | ||||
Reflected Ripple Current | - | -- | 50 | -- | mA | |
Impulse voltage (Isec.max) | 12VDC Input Series | -0.7 | -- | 25 | VDC | |
24VDC Input Series | -0.7 | -- | 50 | |||
Start voltage | 12VDC nominal input series, nominal input voltage | - | - | 9 | ||
24VDC nominal input series, nominal input voltage | - | - | 18 | |||
Input undervoltage protection | 12VDC nominal input series, nominal input voltage | 5.5 | 7.0 | - | ||
24VDC nominal input series, nominal input voltage | 13 | 16.0 | - | |||
Output voltage accuracy | 5%~100% no-load, input voltage range | 3.3V/5V output | -- | ±3.0 | ±5.0 | % |
others | -- | ±1.0 | ±2.0 | % | ||
Line Regulation | Full load, input voltage changes from low voltage to high voltage | -- | ±0.5 | ±1.0 | % | |
Load Regulation | 5%~100% load | -- | ±0.5 | ±1.5 | % | |
Transient Recovery Time | 25% load step change | -- | ±5 | ±8 | mS | |
Transient response bias | -- | ±3 | ±5 | % | ||
Ripple&Noise | Pure resistive load, 20MHz bandwidth, peak to peak value | -- | 50 | 130 | mVp-p | |
Temperature drift coefficient | full load | -- | ±0.02 | ±0.03 | %/°C | |
Short Circuit Protection | Sustainable, self-healing | |||||
Note:The testing method for ripple and noise is the twisted pair testing method. |
