URB2405LMD-30WR3 URB2403/2412/2415/2424LMD-30WR3 DC DC isolated Voltage Regulating Power Supply Converter Module
Visitor3839
Price$9.50
1. Wide input voltage range 4:1, isolated regulated output 30W
4. Quick Start:1mS(Typ)
Input voltage range(fully loaded/unloaded) | 24VDC Input Series | 3.3V | - | 782/208 | 800/30 | mA |
5V | - | 926/259 | 947/35 | |||
12V | - | 926/1.5 | 947/2 | |||
15V | - | 916/1.5 | 937/2 | |||
24V | - | 916/1.5 | 937/2 | |||
±5V | - | 968/25 | 992/35 | |||
±12V | - | 926/1.5 | 947/2 | |||
±15V | - | 926/1.5 | 937/2 | |||
±24V | - | 936/2 | 957/2 | |||
48VDC Input Series | 3.3V | - | 391/10 | 400/15 | ||
5V | - | 463/12 | 474/18 | |||
12V | - | 458/1 | 469/1.5 | |||
15V | - | 458/1 | 469/1.5 | |||
24V | - | 458/1 | 469/1.5 | |||
±5V | - | 484/1 | 496/1.5 | |||
±12V | - | 458/1 | 496/1.5 | |||
±15V | - | 458/1 | 496/1.5 | |||
±24V | - | 468/2 | 478/2 | |||
110VDC Input Series | 3.3V | - | 173/1 | 177/2 | ||
5V | - | 206/1 | 213/2 | |||
12V | - | 202/0.3 | 206/0.5 | |||
15V | - | 200/0.3 | 204/0.5 | |||
24V | - | 200/0.3 | 204/0.5 | |||
±5V | - | 211/0.3 | 216/0.5 | |||
±12V | - | 202/0.3 | 206/0.5 | |||
±15V | - | 200/0.3 | 204/0.5 | |||
±24V | - | 200/0.3 | 204/0.5 | |||
Reflected Ripple Current | Nominal Input Series | -- | 4 | -- | mA | |
Impulse voltage (Isec.max) | 24VDC Input Series | -0.7 | -- | 50 | ||
110VDC Input Series | -0.7 | -- | 180 | |||
Start voltage | 24VDC nominal input series, nominal input voltage | - | - | 9 | ||
48VDC nominal input series, nominal input voltage | - | - | 18 | |||
110VDC nominal input series, nominal input voltage | - | - | 40 | |||
Input undervoltage protection | 24VDC nominal input series, nominal input voltage | 5.5 | 8 | - | ||
110VDC nominal input series, nominal input voltage | 30 | 34 | - | |||
Input filter type | PI filter type | |||||
Output load | load percentage | 0% | - | 100% | 0% | - | 100% | |
