  4. DC DC 30W
  5. URA1D05LD-30WR3 URA1D12LD/URA1D15LD/URA1D24LD DCDC isolated power module with 110v to 3.3/9/12/15/24V dual output power converter
    $8.79
URAXX_LD-30WR3 Series Mode list 拷贝 2
UR(A)B_LD-30WR3 series product output power is 30W,4:1 wide voltage input range,efficiency up to 91%conversional isolation volatge of 1500VDC,allowable operating temperature is -40℃to+85℃,
  • Wide input voltage range(4:1),Output 30W
  • Conversion efficiency91%(Typ
  • Isolation voltage 1500Vdc
  • Ultra low power consumption:0.036W(Typ)
  • Fast startup:1ms(Typ)
  • Working temperature range-40°C~+85℃
  • Input undervoltage , output short circuit , overcurrentovervolatge protection
  • Metal case,low output ripple
  • International standard pins,PCB board in-line
Storage temperture-40—+80 ℃
Related input voltage48Vdc
Input voltage range18-75Vdc
Maximum input current≤1.45A
Reflected rippleNominal input voltage   40mA
DC 5V rated input voltage series
Impulse voltage≤100Vdc
Starting voltage18Vdc
Input undervoltage protection12-15.5Vdc
Start-up delay1msRated input voltage and constant resistance load
PI version
No load rated output voltage5V±2%Vdc
Short-time maximum output current≥6000mA
Rated output current5900mA
Voltage regulation±0.5%
Load regulation ±0.5%
Transfer efficiency Vin=5Vdc, output full load 90%
Output ripple and noise (mVp-p)Pure resistive load, 20MHz bandwidth, peak to peakmV
Output over-current protection
the maximum load 110-200% Vdc
Component No.24V Input Product 48V Input Product 110V Input Product
FMSE FuseAccess the corresponding fuse accrding to customer needs
MOV/Varistor14D560K14D101K14D201K
LDM1/Common mode inductance10mH15mH30mH
CO,C1 Ceramic capacitors100μF/50V100μF/100V100μF/200V
E1,E2 Electrolytic capacitor1μF/50V1μF/100V0.47μF/250V
LDM2/Differential mode inductance10μH15μH68μH
CY1/Y2 Capacitance1nF/250vAC
