24V to 12V 5W 0.42A DC to DC Isolation Voltage 1500VDC Power Module Converter VRB2412YMD-5WR3
Visitor1792
Price$2.77
1. Wide input voltage range 2:1, isolated regulated output 5W
4. Quick Start:1mS(Typ)
Input voltage range(fully loaded/unloaded) | 12VDC Input Series | 3.3V | - | 428/25 | 440/30 | mA |
others | - | 534/25 | 548/30 | |||
24VDC Input Series | 3.3V | - | 214/13 | 220/15 | ||
others | - | 267/13 | 274/15 | |||
48VDC Input Series | 3.3V | - | 107/7 | 110/8 | ||
others | - | 134/7 | 137/8 | |||
110VDC Input Series | 3.3V | - | 47/3 | 48/4 | ||
others | - | 58/3 | 60/4 | |||
Reflected Ripple Current | 12VDC Input Series | -- | - | -- | mA | |
24VDC Input Series | -- | - | -- | |||
48VDC Input Series | -- | - | -- | |||
Impulse voltage (Isec.max) | 12VDC Input Series | -0.7 | -- | 30 | VDC | |
24VDC Input Series | -0.7 | -- | 50 | |||
Start voltage | 12VDC nominal input series, nominal input voltage | - | - | 9 | ||
24VDC nominal input series, nominal input voltage | - | - | 18 | |||
48VDC nominal input series, nominal input voltage | - | - | 36 | |||
110VDC nominal input series, nominal input voltage | - | - | 72 | |||
Input undervoltage protection | 24VDC nominal input series, nominal input voltage | 5.5 | 6.5 | - | ||
110VDC nominal input series, nominal input voltage | 32 | 36 | - | |||
