  4. DC DC 25W
  5. URB4805YMD-25WR3 URB4809YMD/URB4812YMD/URB4815YMD/URB4824YMD DC DC 25W isolated power module 24V to 3/5/9/12/15/24V regulated dual output converter
    $7.00
URBXX_YMD-25WR3 Series Mode list 拷贝 2
1. Wide input voltage range 4:1, isolated regulated output 25W
3. Transfer efficiency up to 91%(Typ)
4. Quick Start:1mS(Typ)
6. Metal case, low output ripple
Ripple & Noise50/80(max)
Mvp-p
ItemWorking conditions
Min.Typ.Max.Unit
Input voltage range(fully loaded/unloaded)24VDC Input Series3.3V-937/20959/2mA
5V-1157/251183/
12V-1157/21183/
15V-1144/21170/
24V-1144/21170/
±5V-1197/21225/
±12V-1157/21183/
±15V-1157/21183/
±24V-1157/21183/
48VDC Input Series3.3V-468/10479/1
5V-578/12591/1
12V-578/1591/2
15V-572/1585/2
24V-572/1585/2
±5V-598/1612/2
±12V-578/1591/2
±15V-578/1591/2
±24V-578/1591/2
Reflected Ripple CurrentNominal input voltage--40--mA
24VDC Input Series-0.7--50
48VDC Input Series-0.7--100
24VDC nominal input series, nominal input voltage--9
PI type
-±1.0%±2.0%-±2.0%±3.0%
±0.2%±0.5%-±1.5%±2.0%
Load adjustment rate
20%~100% rate
load, balanced
±0.5%
±1.0%-±4.0%±5.0%
