24V to 5V 5W 1A DC to DC Isolation Voltage 1500VDC Power Module Converter URB2405YMD-5WR3
Visitor2145
Price$3.15
1. Wide input voltage range 4:1, isolated regulated output 5W
3. Transfer efficiency up to 90%
4. Quick Start:1mS(Typ)
Input voltage range(fully loaded/unloaded) | 24VDC Input Series | 3.3V | 201/1 | 206/2 | mA |
others | 245/1 | 251/2 | |||
48VDC Input Series | 3.3V | 100/0.5 | 103/1 | ||
others | 123/0.5 | 126/1 | |||
110VDC Input Series | 3.3V | 44/0.3 | 45/0.5 | ||
others | 50/0.3 | 55/0.5 | |||
Reflected Ripple Current | 24VDC Input Series | -- | 40 | -- | mA |
48VDC Input Series | -- | 30 | -- | ||
110VDC Input Series | -- | 20 | -- | ||
Impulse voltage (Isec.max) | 24VDC Input Series | -0.7 | -- | 50 | VDC |
110VDC Input Series | -0.7 | -- | 200 | ||
Start voltage | 24VDC nominal input series, nominal input voltage | - | - | 9 | |
48VDC nominal input series, nominal input voltage | - | - | 18 | ||
110VDC nominal input series, nominal input voltage | - | - | 40 | ||
Input undervoltage protection | 24VDC nominal input series, nominal input voltage | 5.5 | 6.5 | - | |
48VDC nominal input series, nominal input voltage | 12 | 15.5 | - | ||
110VDC nominal input series, nominal input voltage | 32 | 36 | - | ||
Linear adjustment rate | input voltage range | - | ±2.0% | ±5.0% | - | ±1.5% | ±2.0% | |
