  4. DC DC 40W
  5. VRB2405LMD-40WR3 VRB2412/VRB241215/VRB241224LMD-40W DC-DC isolated power converter module
    $8.75
VRBxxxxLMD-40WR3 Series Mode list 拷贝
1. Wide input voltage range 2:1, isolated regulated output 40W
4. Quick Start:1mS(Typ)
Ripple & Noise50/80(max)
Mvp-p
Input voltage range(fully loaded/unloaded)12VDC Input Series12V-3702/43786/6mA
15V-3702/43744/6
24v-3702/43744/6
24VDC Input Series5V-1915/21960/3
12V-1951/21893/3
15v-1831/21872/3
24v-1831/21872/3
48VDC Input Series5V-936/1957/2
12V-936/1957/2
15V-925/1946/2
24V-915/1936/2
110VDC Input Series5V-417/0.5427/1
12V-404/0.5413/1
15V-399/0.5408/1
24V-399/0.5408/1
Reflected Ripple Currentnominal Input Series
--40--mA
Impulse voltage  (Isec.max)12VDC Input Series
-0.7--25
24VDC Input Series
-0.7--50VDC
48VDC Input Series
-0.7--100
110VDC Input Series
-0.7--180
Start voltage12VDC nominal input series, nominal input voltage
9
24VDC nominal input series, nominal input voltage
--18
48VDC nominal input series, nominal input voltage
--36
110VDC nominal input series, nominal input voltage
--72
Input undervoltage protection12VDC nominal input series, nominal input voltage
5.58.0
1215.5-
2634-
3036-
PI filter type
-±1.0%±2.0%-±2.0%±3.0%
±0.2%±0.5%-±1.5%±2.0%
Load adjustment rate
20%~100% rate
load, balanced
±0.5%
±1.0%-±4.0%±5.0%
FMSEselected according to the actual input current of the customer
