B0505S-3WR3 power module B0503/B0509/B0512/B0515/B0524S-3WR3 isolated non stabilized voltage power converter
Visitor4701
Price$1.08
Constant voltage input, isolatedunregulated output, 3W power
Isolation voltage: 1500VDC
Low no-load power consumption: 0.025W
Efficiency: up to 90% (Typ.)
Working temperature: -40°C~+85°C
MTBF > 3.5 million hours
Output short circuit protection: sustainable short circuit protection,automatic recovery
Small SIP package, Plastic housingInternational standard pin out
Ripple/noise (20MHz bandwidth)30mVp-p
Input current (full load/no load) | 5VDC Input Series | -- | 682/5 | --/10 | mA |
9VDC Input Series | -- | 379/5 | --/10 | ||
12VDC Input Series | -- | 284/2 | --/5 | ||
15VDC Input Series | -- | 227/2 | --/4 | ||
24VDC Input Series | -- | 142/1 | --/2 | ||
Reflection ripple current | -- | 15 | -- | mA | |
Impulse voltage(1sec.max.) | 5VDC Input Series | -0.7 | -- | 9 | VDC |
9VDC Input Series | -0.7 | -- | 15 | ||
12VDC Input Series | -0.7 | 18 | |||
Items | Working and testing condition | Min. | Typ. | Max. | Unit | |
Output load | Load percetage | 10 | -- | 100 | % | |
Output Voltage Accuracy | See error envelope graph | -- | -- | ±15.0 | % | |
Linear adjustment rate | Input voltage variation ±1% | 3.3V output | -- | -- | ±1.5 | % |
Others | -- | -- | ±1.2 | % | ||
Load adjustment rate | 10%~100% load | 5VDC Output | -- | 12 | -- | % |
9VDC Output | -- | 8 | -- | % | ||
12VDC Output | -- | 7 | -- | % | ||
15VDC Output | -- | 6 | -- | % | ||
24VDC Output | -- | 5 | -- | % | ||
Pin description
