URB2405S-3WR3 URB2403/09/12/15/24VS-3WR3 DC to DC 24V to 3.3V/5V/9V//12V/15V/24V Isolation Voltage Power Module Converter
Visitor4639
Price$1.85
1. Wide input voltage range 4:1, isolated regulated output 3W
3. Transfer efficiency up to 81%
7. Small SIP package
Ripple & Noise | 50/100(max) | Mvp-p |
Input voltage range | 5VDC Input Series | 4.5 | 12 | 18 | VDC |
24VDC Input Series | 9 | 24 | 36 | ||
48VDC Input Series | 18 | 48 | 75 | ||
12VDC Input Series | -- | 320/15 | 328/30 | ||
Linear adjustment rate | Full load, input voltage from low voltage to high voltage | -- | ±3.0 | ±5.0 | % | |
Load adjustment rate | 5%~10% load | 3.3VDC Output | -- | ±0.4 | ±75 | % |
CY1 safety capacitor | 1nF/2KV | |
D1 diode | RB160M-60V/1A | |
R resistance | R=((Vc-Vd-1.0)/Ic)-300Ω | |
Cd | 47nF/100V |
