  3. Communication Module
  4. Lora Module
  5. Hi-link Serial Port to LoRa Wireless RF Communication Module HLK-L06 Long Distance Ultra Low Power IoT Module
    $2.52
L06-3
Product Descrption
HLK-L06 uses chips as wireless communication to achieve data transmission from serial port to wireless radio frequency. It has the characteristics of long transmission distance, low power consumption, strong anti-interference ability, and convenient use
  • Support data conversion from serial port to RF
  • The main frequency supports 32MHz
  • The main controller uses PY32F003 as the main controller
  • Using LLCC68 for communication, with a communication frequency of 433Mhz and a long transmission distance
  • Working voltage 3.0-3.6V, typical value 3.3V
  • Compatible with B36 module packaging and external antenna
  • Supports configuration of transmission rate and power for at commands
  • Maximum transmission power 22dBm
  • Supports one-to-one and one to many communication
Technical Specifications
Module
ModeHLK-L06
PackageDirect insertion/SMT
Antenna parametersfrequency range 433.040 - 434.790Mhz
Transmission powermaximum 22dBmProgrammable adjustment
Receiving sensitivity-129dBm
Antenna formExternal: I-PEX connector
Hardware parametershardware interface UART
working voltage 3.3V(3.0-3.6v)
Communication rateModulation method: 1.11-18.23Kbps
Working current
Continuous transmission:~120mA, maximum transmission power
Receiving mode: 5mA
working temperature -40℃~85℃
Serial port transparent transmissiontransmission speed 9600-115200bps
User ConfigurationAT+instruction set
Application
