  4. DC DC 3W
  5. URB4805S-3WR3 URB4803/09/12/15/24VS-3WR3 DC to DC 24V to 3.3V/5V/9V//12V/15V/24V Isolation Voltage Power Converter Module
    $2.46
URB24XXS-3W Series Mode list  拷贝
1. Wide input voltage range 4:1, isolated regulated output 3W
3. Transfer efficiency up to 81%
7. Small SIP package
Ripple & Noise50/100(max)
Mvp-p
Input voltage range
5VDC Input Series4.51218VDC
24VDC Input Series92436
48VDC Input Series184875
12VDC Input Series--320/15328/30
24VDC Input Series--160/6164/10
48VDC Input Series--80/482/6
12VDC Input Series
40--
24VDC Input Series
55--
48VDC Input Series
45--
Impulse voltage(1sec.max.)5VDC Input Series-0.7--12VDC
12VDC Input Series-0.7--25
24VDC Input Series-0.7--50
48VDC Input Series-0.7--100
Starting voltage5VDC nominal input series, nominal input voltage--4.5
12VDC nominal input series, nominal input voltage--9
Linear adjustment rateFull load, input voltage from low voltage to high voltage--±3.0±5.0%
No-load output voltage accuracyInput voltage range--±1.5±5.0%
Output Voltage Accuracy5%-100% load, input voltage range3.3V/5V Input--±3.0±5.0%
others--±1.0±3.0%
Load adjustment rate5%~10% load3.3VDC Output--±0.4±75%
Transient recovery time25% load step change
--0.52ms
Transient Response Bias
--±2.5±5%
Ripple & NoisePure resistive load, 20HMz bandwidth, peak-to-peak--50100mVp-p
--±0.02±0.03%/℃
CY1 safety capacitor1nF/2KV
D1 diodeRB160M-60V/1A
R resistanceR=((Vc-Vd-1.0)/Ic)-300Ω
Cd47nF/100V
PIN DESCRIPTION 拷贝
