  4. DC DC 3W
  5. B2405S-3WR3 power module B2403/B2409/B2412/B2415/B2424S-3WR3 isolated non stabilized voltage power converter
    $1.38
ownload files:
5W: hhttps://drive.google.com/drive/folders/1okF0YdP1Xs35HxnAkTm45WOK0kH7qlb5?
B_S-3WR3 Series Mode list 拷贝
  • Constant voltage input, isolatedunregulated output, 3W power
  • Isolation voltage: 1500VDC
  • Low no-load power consumption: 0.025W
  • Efficiency:  up to 90% (Typ.)
  • Working temperature: -40°C~+85°C
  • MTBF > 3.5 million hours
  • Output short circuit protection: sustainable short circuit protection,automatic recovery
  • Small SIP package, Plastic housingInternational standard pin out
  • Ripple/noise (20MHz bandwidth)30mVp-p
Input current (full load/no load)5VDC Input Series--682/5--/10mA
9VDC Input Series--379/5--/10
12VDC Input Series--284/2--/5
15VDC Input Series--227/2--/4
24VDC Input Series--142/1--/2
Reflection ripple current
--15--mA
Impulse voltage(1sec.max.)5VDC Input Series-0.7--9VDC
9VDC Input Series-0.7--15
12VDC Input Series-0.7
18
15VDC Input Series-0.7--21
24VDC Input Series-0.7--30
ItemsWorking and testing conditionMin.Typ.Max.Unit
Output loadLoad percetage10--100%
Output Voltage AccuracySee error envelope graph----±15.0%
Linear adjustment rateInput voltage variation ±1%3.3V output----±1.5%
Others----±1.2%
Load adjustment rate10%~100% load5VDC Output--12--%
9VDC Output--8--%
12VDC Output--7--%
15VDC Output--6--%
24VDC Output--5--%
----±0.03%/℃
Pin description
B24_S-3WR3-PIN DEFINITION 拷贝
dimension
