WRA1205S-3WR3 isolated power module WRA1203/2409/WRA1212/WRA122424S-3W dual output Power Converter
Visitor4305
Price$3.00
3W, wide voltage input, isolated and stabilized positive and negative dual channel single output
Ultra compact SIP packaging
Wide input voltage range: 2:1
Working temperature range: -40 ° C to+85 ° C
Isolation voltage 1500VDC
Low ripple noise
Short circuit protection (self recovery)
Output can be turned off
Input voltage range | 5VDC Input Series | 4.5 | 5 | 9 | VDC |
12VDC Input Series | 9 | 12 | 18 | ||
24VDC Input Series | 18 | 24 | 36 | ||
48VDC Input Series | 36 | 48 | 72 | ||
Input current (full load/no load) | 5VDC Input Series | -- | 833/40 | 857/60 | mA |
12VDC Input Series | -- | 320/15 | 328/30 | ||
Reflection ripple current | 5VDC Input Series | -- | 30 | -- | mA |
Hot plugged | Non-support | ||||
Remote pin(Ctrl)* | Module enabled | Ctrl end suspended or high resistance | |||
Module shutdown | Connect the high level (relative to the input ground) so that the current flowing into the Ctrl terminal is 5-10mA |
Linear adjustment rate | Full load, input voltage from low voltage to high voltage | -- | ±0.2 | ±0.5 | % | |
Load adjustment rate | 5%~100% load | -- | ±0.4 | ±75 | % | |
Component No. | 5V Input | 12V Input | 24V Input | 48V Input |
FMSE | Slow blowing fuse, selected according to the actual input current of the customer | |||
MOV varistor | - | 14D390K | 14D560K | 14D101K |
LDM1 inductance | 12uH | 12uH | 12uH | 12uH |
Co electrolytic capacitor | 1000μF/16V | 1000μF/25V | 330μF/50V | 330μF/100V |
C1 ceramic capacitor | 4.7μF/50V | 4.7μF/50V | 4.7μF/50V | 4.7uF/100V |
C2 ceramic capacitor | 4.7μF/50V | 4.7uF/50V | 4.7uF/50V | 4.7uF/100V |
Cout ceramic capacitor | ||||
CY1 safety capacitor | 1nF/2KV | |||
D1 diode | RB160M-60V/1A | |||
R resistance | According to the formula:R=((Vc-Vd-1.0)/1c)-300Ω | |||
Cd | 47nF/100V |
