URB4805LMD-40WR3 URB4812/URB4815/URB4824LMD-40W DC-DC isolated power converter module
Visitor3926
Price$10.55
1. Wide input voltage range 4:1, isolated regulated output 40W
4. Quick Start:1mS(Typ)
Input voltage range(fully loaded/unloaded) | 24VDC Input Series | 12V | - | 1851/2 | 1893/3 | |
15v | - | 1831/2 | 1872/3 | |||
24v | - | 1831/2 | 1872/3 | |||
48VDC Input Series | 5V | - | 946/1 | 968/2 | ||
9V | - | 936/1 | 957/2 | |||
12V | - | 936/1 | 957/2 | |||
15V | - | 925/1 | 946/2 | |||
24V | - | 915/1 | 936/2 | |||
110VDC Input Series | 5V | - | 413/0.5 | 422/1 | ||
9V | - | 404/0.5 | 413/1 | |||
12V | - | 404/0.5 | 413/1 | |||
15V | - | 399/0.5 | 408/1 | |||
24V | - | 399/0.5 | 408/1 | |||
Reflected Ripple Current | nominal Input Series | -- | 40 | -- | mA | |
Impulse voltage (Isec.max) | 24VDC Input Series | -0.7 | -- | 50 | VDC | |
110VDC Input Series | -0.7 | -- | 180 | |||
Start voltage | 24VDC nominal input series, nominal input voltage | - | - | 9 | ||
48VDC nominal input series, nominal input voltage | - | - | 18 | |||
110VDC nominal input series, nominal input voltage | - | - | 40 | |||
Input undervoltage protection | 24VDC nominal input series, nominal input voltage | 5.5 | 8.0 | - | ||
110VDC nominal input series, nominal input voltage | 30 | 34 | - | |||
Input filter type | PI filter type | |||||
Linear adjustment rate | input voltage range | - | ±0.2% | ±0.5% | - | ±1.5% | ±2.0% | |
FMSE | selected according to the actual input current of the customer | |
