24V to 3.3V 3W 600mA DC to DC Isolation Voltage 1500VDC Power Module Converter WRB2403S-3WR3
Visitor1671
Price$2.71
1. Wide input voltage range 2:1, isolated regulated output 3W
3. Transfer efficiency up to 83%
7. Small SIP package
Ripple & Noise | 50/100(max) | Mvp-p |
Input voltage range | 5VDC Input Series | 4.5 | 5 | 9 | VDC |
12VDC Input Series | 9 | 12 | 18 | ||
24VDC Input Series | 18 | 24 | 36 | ||
48VDC Input Series | 36 | 48 | 72 | ||
Input current (full load/no load) | 5VDC Input Series | -- | 833/40 | 857/60 | mA |
12VDC Input Series | -- | 20/15 | 328/30 | ||
Reflection ripple current | 5VDC Input Series | -- | 30 | -- | mA |
Linear adjustment rate | Full load, input voltage from low voltage to high voltage | -- | ±3.0 | ±5.0 | % | |
Load adjustment rate | 5%~10% load | 3.3VDC Output | -- | ±0.4 | ±75 | % |
CY1 safety capacitor | 1nF/2KV | |
D1 diode | RB160M-60V/1A | |
R resistance | R=((Vc-Vd-1.0)/Ic)-300Ω | |
Cd | 47nF/100V |
